Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 5th October 2013, 11:23 PM   #2561
woofertester is offline woofertester  United States
Originally Posted by Lazy Cat View Post
Hi Odysseas
Last 30 VSSA PCB sets are waiting to be send out as soon as I'll get assembled PCB's from manufacturer.
I aligned numbers of received ALF mosfets and PCB's since there were inquiries up to the last piece. Cannot help for the time schedule since it doesn't depends just from me.
Remaining 7 GB members to receive VSSA as soon as possible:
milandks 4 PCB set
audionootje 4 PCB set
ua3grn 6 PCB set
Odysseas 4 PCB set
edbk 4 PCB set
woofertester 4 PCB set
Metallicus69 4 PCB set
Regards L.C.
Thank you for the update LC. I am looking forward to using your VSSA boards.
Old 9th October 2013, 12:19 AM   #2562
bimo is offline bimo  Indonesia
bimo's Avatar
I try to change compensation in simulation. It give better distortion in 20kHz and wider bandwidth.
I ask all masters here, if this compensation will give VSSA stable?
I will try this compensation in my VSSA later.
Old 9th October 2013, 04:49 AM   #2563
meanman1964 is offline meanman1964  Belgium
meanman1964's Avatar
Originally Posted by meanman1964 View Post
Lazy Cat please remove some mails mine doesn't get trough
Maybe you can send me a mail
Can you tell me the dimensions of the case you've used for the VSSA and if they are still for sale.Maybe I need ten of them all depends on the price.
Patrick
LazyCat,where are you?????
Old 9th October 2013, 09:55 PM   #2564
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Assembling three First One-s for the exhibition, haven't sleep for a few days. :P
I'll be back
Old 9th October 2013, 09:58 PM   #2565
Lazy Cat's Avatar
In sim only, in reality 15 MHz oscillator
Old 9th October 2013, 10:41 PM   #2566
Esperado is offline Esperado  France
Banned
Don't believe in Reality :-)
Old 9th October 2013, 11:00 PM   #2567
BYRTT is offline BYRTT  Denmark
I'll be back
Hey then good fight with solderiron....
Nice exhibition and audio talk/gossip...........
And good night when bedtimes come..................... ...
Old 10th October 2013, 01:11 PM   #2568
bimo's Avatar
How much practically maximum ULGF in VSSA if we try another compensation?
Old 10th October 2013, 04:39 PM   #2569
analog_sa is offline analog_sa  Europe
analog_sa's Avatar
Have two questions:
1. Converting input to 2sk246/2sj103 in order to raise input impedance. Any obvious issues?
2. Gain variations - just need about +-1db, but what are the safe limits to vary gain?
Thanks.
Old 10th October 2013, 05:30 PM   #2570
Banned
To bimo and analog_sa, the only way to get an answer to your question is to... try by yourself. :-)
Maximum ULGF is only the one you can get stable with your real build, ...experimenting.
Fets input VS BJT ? The one you prefer (on your listening experiences). While you can prefer a single path feedback network with fets ? An other amp. Fets are better for EMI/RFI, while a little more 'grainy' ?
May-be they will be at their best with different gain ?
High input impedance ? What the need, as we prefer it as low as possible, preamp side ?
Gain variations ? Same response than ULGF. More open loop gain, more feedback, less distortion, less stability... Listen and chose your best compromise, the only way...
Or take for granted that L.C. had spend a lot of time to do all those experiments, and save time using his amp as-it :-)
That i will do, on my side, with may-be a little try to increase PSRR, with a VAS/Input rails external regulation and tune the low pass filter FC in my real hifi system configuration.
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
Copyright ©1999-2017 diyAudio
