Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 31st December 2012, 06:30 PM   #231
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by gaborbela View Post
Do these capacitor will degrade or effect the sound in a negative way?
sounds like they have more positive effect than negative
Old 1st January 2013, 08:45 PM   #232
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
VSSA measurements, +/- 32 V rails
1.pic - 50 kHz square wave, 20,7 Vrms/8 ohm, 2,5 Arms
2.pic - the same as first only 0,22 uF parallel to 8 ohm load
Not bad for six transistors amplifier with no CCS.
Old 2nd January 2013, 07:38 AM   #233
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Originally Posted by Lazy Cat View Post
P.S. Miller caps are 12 pF SMDs and VSSA is completely stable.
Hi LC, are you using classical NPO smd brand for miller cap?
Marc
website : http://audiyofield.wifeo.com/index.php
Old 2nd January 2013, 07:49 AM   #234
Lazy Cat's Avatar
RF quality SMD capacitors. Copper heatsink is in electrical connection to sources of ALF, so a little portion of capacitance coming from here is in addition to Miller cap too.
I'll try to replace injection resistors with CCS to see possible improvement in the next test.
Regards L.C.
Old 2nd January 2013, 07:53 AM   #235
Idefixes's Avatar
Thanks, what do you mean by copper heatsink?
Marc
Old 2nd January 2013, 08:11 AM   #236
Idefixes's Avatar
LC one more question : in his layout Alex swap the 1000uf 50v implicated in first stage power supply to 470uf 50V is that sufficient to your taste?
Marc
Old 2nd January 2013, 07:58 PM   #237
Idefixes's Avatar
Not fully satisfied with data i found about small heatsink for VAS i decided ti swap to ones well known and that i have in stock. Miller caps has swap to RF SMD type the more close i could to Vas transistors legs.
Old 2nd January 2013, 08:45 PM   #238
sonnya is offline sonnya  Denmark
sonnya's Avatar
You could hack this amp.
http://www.diyaudio.com/forums/solid...ml#post3213913
Use the output stage (M1, M2), the buffer which makes the mosfet switch fast (Q15,Q18 R4,C1,R21,R13,R14), use the VAS (Q7,Q6,Q5,C3,C4,Q8,Q9,Q10,R5 - R8)
Q5,Q8,Q15,Q18 can easily be DZT5401,DZT5551.
The general bias in this amp is very low. V4 can be a trim resistor with 47uF in parallel. Or as Lazycat TL431.
We are down to 4 - 8W per channel from +/-35VDC supply.
The use the frontend of the VSSA.
C3 and C4 is in reallife 47pF each.
Old 2nd January 2013, 10:36 PM   #239
pergo is offline pergo  Italy
pergo's Avatar
two CRDs instead the 470ohm resistors (input pair's collector to rail), improve THD by 30%, mostly 2nd order.
Nessuno puņ farvi sentire inferiori senza il vostro consenso
Mr.P Electronics
Old 3rd January 2013, 07:45 AM   #240
Lazy Cat's Avatar
What do you mean? To combine two amps? Please elaborate Sonny.
At VSSA we are fixed to six transistors only, as promised.
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 11:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 12:47 PM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 07:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
Copyright ©1999-2017 diyAudio
