Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 13th July 2013, 08:16 PM   #1871
Idefixes is online now Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
So VSSA is on progress but i don't think it will be singing this weekend....One chanel is at 95% mounted but i need to purchase some little things as signal wire, and minor connectic...
Marc
website : http://audiyofield.wifeo.com/index.php
Old 13th July 2013, 09:24 PM   #1872
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Now listening Keith Jarrett's Up for It live album and I can only say, after connected back both genuine VSSA channels, it is simply better. It has that magic sparkle and liveliness no other amp has.
Old 13th July 2013, 09:30 PM   #1873
Idefixes's Avatar
My monobloc test chassis. I have to build the second one...
Old 13th July 2013, 09:38 PM   #1874
brianco is offline brianco  Ireland
brianco's Avatar
Location: Scottish Borders - Kelso; on the famous Tweed River!
I have a similar monobloc in design! [Reason being to use short speaker cables and long interconnects. (Otherwise they have to live in a poorly ventilated cupboard!)]
Do you intend to have a ventilation slot below and above the amp. PCB?
Old 13th July 2013, 10:15 PM   #1875
Idefixes's Avatar
This is just a test chassis it will remain as showned on picture. Heatsink are visually damage and shown many drill => was heatsinking TO3 devices. So it's perfect for test but not for definitv housing.
Marc
Old 14th July 2013, 09:43 AM   #1876
Junie is offline Junie  Philippines
Originally Posted by Lazy Cat View Post
Hi Junie
Here's what would help you out. DC Sense Protect out connect to Connector C pin 6, 8.
Hi Andrej,
Thanks!
I will connect DC sense (L and R) in parallel to Conn. C pin 6 & 8?
Junie
Old 14th July 2013, 12:08 PM   #1877
metallicus69 is offline metallicus69  Netherlands
My JC-80 is ready to feed the VSSA. Also, my VSSA modules are ready to be mounted, feed and testing. Still need to decide what to use as the power supply... A toroid that is a bit on the small side (250VA) with 4 separate 28V windings, or a bigger one (500VA) with similar 4x 28V windings. It depends also on the internal size of the case.
@LC, can you please post some details?
Cheers!
Old 14th July 2013, 04:16 PM   #1878
VSSA in calibration but the T1 and T2 is really hot! help please.
Old 14th July 2013, 07:48 PM   #1879
Ok I sorted it out, I have a bridge solder from +in to nearby resistor, my mistake obviously .
Please see below sine/square wave at 1Khz.
Good night everyone, I sat on this amp the whole day and I need some sleep.
Old 15th July 2013, 09:42 AM   #1880
nikosokey is offline nikosokey  Greece
nikosokey's Avatar
Junie
Have you tried Square 100 khz at full wave p-p with 8Ω load ?
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
Copyright ©1999-2017 diyAudio
