Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 26th June 2013, 06:27 AM   #1661
miksi is offline miksi  Serbia
Well, I've manage to screw up one channel. I am using single ended outputs from TPA IVYIII directly coupled to VSSA. First I had hum from both channels when connected to DAC but that was cured with proper grounding arangements similar to what Andrej has in his latest amp box. RCAs was not connected and when tried with speakers it was dead silent, no hum, no buz. After connecting with DAC, I've realized that amp was already on when I tried to switch it ON . Now on one channel I have 0.5V and rising in the matter of seconds to over 1 volt DC. Other channel is perfectly fine. I will check input pair and hope nothing happend to ALFets.
Old 26th June 2013, 10:07 AM   #1662
Input pair is OK. Resistor R19 10ohm smd 2010 in negative rail was the problem. It looks normal but not conductive. It must be stressed out due to capacitor charging (frequent on/off switching for adjusting). I can't find any smd 2010 so I will put 10+10||10+10 1/4w smd.
Old 26th June 2013, 03:23 PM   #1663
bressix is offline bressix
I got mine boards yesterday .
Thank you Andrej
Old 26th June 2013, 10:08 PM   #1664
supernet is offline supernet  Europe
supernet's Avatar
Hypex PSU transformation
Panasonic EE and FM capacitors already in place...
Old 27th June 2013, 01:09 AM   #1665
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Very good miksi, do not stop till you make it, I guarantee you won't be dissapointed.
Old 27th June 2013, 01:11 AM   #1666
Lazy Cat's Avatar
Good job supernet, all SMPS's elcos replaced, VSSA will rock.
Old 27th June 2013, 01:17 AM   #1667
Lazy Cat's Avatar
Originally Posted by metallicus69 View Post
P.S.: I will build the VSSA anyway in the next month, as I am sure it will be a major step forward, but I need to have a future next project
Hi metallicus69
Agree on that, first VSSA and than balanced (bridged) version. I think balanced version comes into consideration only for 8+ Ohm speakers or driving some drivers directly in an active speakers system. Anyway worth to try it, I cannot promise anything, very busy lately.
Old 27th June 2013, 01:41 AM   #1668
Lazy Cat's Avatar
Since we are in vendors forum I'll go full blast on VSSA marketing and therefore promote new Alu-chassis made especially for VSSA and SMPS400A180 modules in dual mono configuration. Here are some pictures of a second VSSA amplifier assembled, from now on with official commercial name Lakner Oné The most transparent amplifier
Few more pics clearly shows how to assemble all pieces together into final product. This one was ordered by local Hi-Fi shop, after heard VSSA demo version they simply cannot forget the VSSA sound signature, which is none. Let me just say that they housed some Clase, Cambridge, Naim and NAD amplification.
Old 27th June 2013, 01:48 AM   #1669
PMI is offline PMI  United States
Originally Posted by Lazy Cat View Post
...Here are some pictures of a second VSSA amplifier assembled, from now on with official commercial name Lakner Oné The most transparent amplifier ...
Old 27th June 2013, 01:55 AM   #1670
kasey197 is offline kasey197
The Dastardly Dad of Three
very very beautiful - congratulations!
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
