Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
ES9018 32bit Audio DAC kit USD89.95
Old 19th March 2013, 03:43 AM   #91
rade95 is offline rade95  United States
I am still puzzled and confused with some of the postings: glt you are talking about a need for 1.2V supply, in addition to 3.3V AVCC and 3.3V DVCC. However I don't see a need for a 1.2V regulator for a v2 board. I just got my v2 board and it has AVCC, DVCC and additional 3 pins marked +12, GND and -12V. I don't get it why does this board require +-12V PS? I am yet to figure out where to source AVCC power supply. For +-12V (if really needed) I will use a TP Placid bipolar PS and for DVCC 3.3V I will use ADP7104 eval board. Any recommendations for AVCC 3.3V regulator?
UGS pre, stock F5, PassLabs X2.5, Aleph P
Old 20th March 2013, 04:50 PM   #92
chicco_36 is offline chicco_36  Macedonia
From the picture (common logic), +-12V are needed for op-amps: filter stage and balanced - single ended converter.
You may use lower voltage or even +-15V, but in later case caps must be rated for 25V.
All the best,
Chicco
Old 18th June 2014, 06:38 PM   #93
Page.P is offline Page.P  Czech Republic
If this module works in hardware mode, what about remapping inputs to source correct DAC(1-8)? I thought it has to be done in SW mode. How does it work in HW mode on this module?
ES9018 32bit Audio DAC kit USD89.95Hide this!Advertise here!
Twisted Pear Audio - Buffalo32S (ES9018 DAC) Russ White Twisted Pear 978 29th November 2015 03:26 AM
ES9018 DUALMONO DAC KIT heartwinter Vendor's Bazaar 7 15th September 2012 09:40 AM
USB to PCM1795 32bit DAC savu Digital Line Level 0 18th April 2012 12:58 PM
Any 32bit Delta Sigma/ R-2R Audio DAC in the world? Comzone Digital Source 3 11th February 2004 03:01 PM
Copyright ©1999-2017 diyAudio
