SB Acoustics Satori Monitor SB Acoustics Satori Monitor - Page 9 - diyAudio
Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 6th October 2012, 09:33 PM   #81
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
So when the Monitor is ready we need a sub ?
Old 7th October 2012, 01:02 AM   #82
Here is my design for an easy to make cabinet that looks good and does the Job as well.
The baffle is staggered and allows delay compensation between the tweeter and the woofer. Diffraction is scattered so the cabinet has less influence on imaging clues. The second version has chamfered edges and should work even better. The edges can also be rounded.
Old 7th October 2012, 01:41 AM   #83
Design number 1 can also be modified by putting felt around the staggered elements making the tweeter baffle flat in essence.
Old 7th October 2012, 08:03 AM   #84
gornir is offline gornir  Sweden
gornir's Avatar
Hi Joachim,
Haven’t you considered using a ”ladder delay network” to electrically address the driver units relative acoustic center off-set instead of using a stepped or slanted baffle?
This would make the loudspeaker enclosure even easier to build, but at the expense of a bit more complicated cross-over design. Sonically it work very well and it’s very easy to fine tune once you have the basic ladder circuit in place.
I’ve found it to work very well when using shallow filters like a true LR2, but it’s over-kill/not necessary to use it with steeper filters.
Here's an example:
Sequence Two – Monitor
Sequence Two – Monitor BE
/Göran
Author of the "AudioExcite Loudspeaker Design" website & Technical Consultant for HULGICHAUDIO
http://www.audioexcite.com http://www.hulgichaudio.com.au/
Old 7th October 2012, 08:11 AM   #85
_henry_ is offline _henry_  Australia
the sketches looks similarly to one of the Sonus Faber's bookshelf.
Old 7th October 2012, 08:57 AM   #86
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
I prefer thick sides over a thick front
a thick baffle is like mounting the driver in a tube, which wouldnt be so good
Old 7th October 2012, 09:02 AM   #87
pinkmouse is offline pinkmouse  Europe
pinkmouse's Avatar
Sure, really deep bass you feel in your body...
Isn't actually that deep, for an average person, body resonance is around 70-120Hz.
Rick: Oh Cliff / Sometimes it must be difficult not to feel as if / You really are a cliff / when fascists keep trying to push you over it! / Are they the lemmings / Or are you, Cliff? / Or are you Cliff?
Old 7th October 2012, 01:18 PM   #88
What you call a "ladder delay network" has not only the effect of delaying the tweeter but it also adds an all pass term so you can not build a time coherent speaker with a ladder network. When i go the the Sequence Two measurements the drivers match in phase only over a quite narrow range. With acoustic delay by mechanical means i can do better WHEN i want to make an all pass crossover.
Henry, please show me the Sonus faber model that looks similar.
Tinitus, a thin baffle is not a very stable playground for the drivers.
Old 7th October 2012, 01:42 PM   #89
here you go
Old 7th October 2012, 02:30 PM   #90
Yes, that looks very similar. Is that an old Guarneri ? And yes, why not doing it the same way ? I think it looks good and is effective.
Here are some other ideas. Two of them are modular.
SB Acoustics Satori MonitorHide this!Advertise here!
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 03:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright ©1999-2017 diyAudio
