Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
SB Acoustics Satori Monitor
Old 11th March 2013, 03:05 PM   #511
ton64 is offline ton64  Netherlands
Joachim,
Nice pictures of your present setup. One of them-the last one-with the blue power capacitors which are bypassed by the red capacitors have my attention. Which value do you have used for trying out? Read: Power Capacitor : Bypass Capacitor? I am working with Mundorf M-LYRIC HC-10.000uF-80VDC. Do you have an advice?
mbrton,
Old 11th March 2013, 03:26 PM   #512
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
The power elcaps are B&C, i think 10.000uF or bigger.
The bypass are WIMA MKT, i think 2.2uF.
The M-lytics are even better, the best i know actually.
The bypass cap is kind of a philosophy.
I can be that when you bypass too strong the combination of elcap and bypass can resonate. I would start with 1uF MKT.
You can go up to more, say 3.3Uf and also can try Polypropylen.
Here on the forum you can find advice of how to optimize but then you have to measure.
Old 11th March 2013, 05:53 PM   #513
Joachim, regarding to the bypass thanks for your quick reply. Back to your Satori project. Looking to these nice picture of your present setup and the enclosure detail with the twisted,read slightly bended shape-I suppose it is made by strong stress/ resistance/ and tension- I must say it is an (very) intelligent way of manufacturing! If is made with wood only matbe it will disappear slowly (?). I enjoy your project very much and follow it with great pleasure.
wmbrton,
Old 11th March 2013, 06:31 PM   #514
So far the cabinets show no sign of deterioration.
They are also heavy braced inside so i think they will be stable over time.
Old 16th March 2013, 04:09 PM   #515
Max Martin is offline Max Martin  Sweden
Max Martin's Avatar
How is the midrange qualities in Satori compared to the Seas Nextel 5 inches you got?
Old 16th March 2013, 04:14 PM   #516
The SEAS drivers are not that well impedance controlled and the Nextel cone is quite heavy.
The Satori has higher sensitivity, lower distortion and is more extended in the higher reaches.
As far as paper cones go i do not know a finer driver at the moment.
Old 18th March 2013, 11:53 PM   #517
Max Martin's Avatar
Thanks, for a honest answer Joachim. Without listening I guessed about the same.
I have some U18RNX/P with woven polycone and they are quite good but they can touch my SB17RNX when it comes to neutrality and open/dynamic midrange. I Also have used and own many Excel and they "excel" on some ways (magnesium cones) but I don't know, Seas is atleast doing much finer 4,5" and 5" drivers in my opinion.
I also now use 4 pcs of Seas L22RN4X/P with good results but my guts says to me "try SB 8" instead...." hehehe Oouscchhh sometimes I got tired of all routering and changing baffles i get sick Maybe should enjoy music too =)
Ok, enough of that... when i read Joachims "bypass-ing" talk i got interested. I use my pc as primary source with a dedicated soundcard and i was thinking maybe that powersupply could use some help? It's a Corsair CX430 with a main Cap rated at 400V/i forgot but i think it was just under 500uF.
Checked my DIY box and there was a 400V/ 1.5uF Mcap MKP, so why not?
An hour later I switch on my tubeamp and there was dark sound signature showing up, like the two upper octaves where missing. I thought instruments sounded maybe a bit better... (listened to Marks new Privateering album) and i got a bit depressed... hmmm... i went to bed cuz it was late.
Next day I didn't bother to listen at all till late at night and this time i got shocked! Wow there was a big step up, suddenly it was like listen to a tubeamp for the first time.. Envolving mid, great dynamics and so on...
Very happy now with that small tweak. Also feel after this that my computer is more stable. And it feels a bit more snappy speedwise too. maybe placebo
Old 19th March 2013, 01:44 AM   #518
I use a lot of the SEAS metal cone drivers ( aluminum ).
This is a different story and needs totally different crossover technology.
When you change caps it needs a bit of time until they settle, especially electrolytics.
Old 19th March 2013, 04:21 AM   #519
Max Martin's Avatar
Yes, hard cones have to taking seriously when doing filter.
The 4 layer coil in my drivers with that high inductance helps alot when making a x-over. Already with a simply 12db (200-400hz) the peak are way down higher up.
There is a finnish brand called Aurelia. All metaldrivers (tweeter from seas titanium) Bas/mid unknown but every critic journalist seems to love them (at least here) Aurelia | The Beauty and the Music
Those I've listened to, wow. Impressive (also the design) but after 2-3 songs my ears bleeding. Maybe with some good tubeamp and varm cables =)
Old 19th March 2013, 05:14 AM   #520
A 4 layer coil also has a disadvantage :
High Inductance. This is frequency and level dependent and creates a nasty type of distortion. When you limit it to the bass, fine.
The Satori is completely impedance compensated and does not have that problem.
The class leading low distortion shows that.
SB Acoustics Satori MonitorHide this!Advertise here!
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 03:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright ©1999-2017 diyAudio
