Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
SB Acoustics Satori Monitor
Old 16th February 2013, 02:04 AM   #451
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I optimised the crossover for ca. 15° off axis. Straight on axis there are some bumps that disappear off axis.
Old 16th February 2013, 02:00 PM   #452
gornir is online now gornir  Sweden
gornir's Avatar
Yes, I usually do the same.
I like the very simple, but yet nicely done filter design.
What I don't like is the low sensitivity! It's to low for my taste and I think the 4 ohm version is a better choice for a small stand-mount monitor.
I think the 8 ohm version would be great for a small 2.5-way floor-stander.
Have you done any distortion tests on the finished design in order to see how the tweeter copes with the low cross-over point and shallow slope?
/Göran
Author of the "AudioExcite Loudspeaker Design" website & Technical Consultant for HULGICHAUDIO
http://www.audioexcite.com http://www.hulgichaudio.com.au/
Old 16th February 2013, 03:04 PM   #453
Thanks, yes there is a price to pay for 8 Ohm and the slim baffle.
Anyway, we have the 4 Ohm version in the Guru clone and i can make a 4 Ohm version for the slim cabinet.
I will build a second speaker today and i will also fit the crossovers so i can listen and measure.
Old 16th February 2013, 11:01 PM   #454
I have now build a pair that works. I know, pride stinks, but they look really classy on the stands in my listening room.
I will now listen but not very loud. It is late here.
I will let them run in over night and listen more, also at high volume, tomorrow.
Old 16th February 2013, 11:50 PM   #455
MiiB is offline MiiB  Denmark
It's easy to lower port resonance, just inlay some foam at the sides to narrow the port a bit...but 51 HZ is not that bad. better to have the speaker do what it does good, than to have it try to do something it cannot...!!
Old 17th February 2013, 01:04 AM   #456
I have now setup the speakers and i have listened quite a bit. I am very impressed about what i hear. This is certainly a low distortion, low energy storage speaker.
The cabinet is superbly quiet and the image is totally free of the speakers unless the signal is pan potted close up straight into left or right, the way it should be but rarely happens. I will tell you more soon.
Old 17th February 2013, 01:33 AM   #457
This is the amp i use :
Elite Series Quad
I left the electronics unchanged but i modified the mechanics.
Old 17th February 2013, 01:38 AM   #458
http://www.methe-family.de/picture/E...erhard%204.jpg
I listen to CD at the moment. I am using a Forsell Air Reference CD tarnsport with a MACE digital pre.
Old 17th February 2013, 01:41 AM   #459
I use a Wire World Gold Eclipse AES-EBU cable into the Mace Digital Pre. The MACE has an on board DA converter and a relay controled line stage.
Old 17th February 2013, 01:43 AM   #460
MACE | audioequipment
The cable between the Mace and the QUAD is a Wire World Silver Elipse.
SB Acoustics Satori MonitorHide this!Advertise here!
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 03:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
