SB Acoustics Satori Monitor SB Acoustics Satori Monitor - Page 43 - diyAudio
Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 23rd January 2013, 02:58 PM   #421
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I have being working on a 4th order version. The crossover then needs a second coil before the woofer plus impedance correction. The tweeter may need a second cap.
I can tune that version to any flatness but i think the additional components are a bit too much for my taste. I will stick with the second order filter.
If you want to construct a 4th order please go ahead.
I will publish a chard that shows how the crossover takes away signal from the tweeter
in the deeper regions with the second order version. I think it is protected well enough, even for high volume.
Old 23rd January 2013, 04:15 PM   #422
Here is the supression curve of the L/R second order version.
File Type: pdf Satori Monitor 12dB gain loss tweeter.pdf (14.2 KB, 526 views)
Old 23rd January 2013, 10:33 PM   #423
Benedetto is offline Benedetto  Germany
Benedetto's Avatar
What shall i say about this ?
Can't wait to hear 'em @ D.burg.
preregulatorpeterE-MAIL
Old 23rd January 2013, 10:35 PM   #424
I bring the prototype to the Mini Frickelfest. See you on 9th of february in Duesburg.
Old 23rd January 2013, 10:40 PM   #425
Benedetto's Avatar
As said before;
can't wait old man.
Old 29th January 2013, 07:52 PM   #426
ridikas is offline ridikas  United States
What kind of engineering is this if part values are not standard?
Old 29th January 2013, 07:59 PM   #427
wintermute is offline wintermute  Australia
just another
wintermute's Avatar
^ no compromise
If you were building a bridge would you only use off the shelf parts if that would mean that it's structural integrity was compromised, or would you ensure that the parts used were completely up to the task?
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 30th January 2013, 06:45 PM   #428
gatewatcher is offline gatewatcher
Mr Gerhard, I think you did a very good job! congrats!
Old 30th January 2013, 08:13 PM   #429
I really do not understand the problem with the parts values. They have to be quite exact or i do not get such good phase matching.
I think resistors and caps are no problem at all. The can be made by paralleling standard values. Also coils can be trimmed. You can buy bigger values and wind them down.
Then you need an LCR meter. I can show you one that is inexpensive but surprising accurate, that meter can be used for a lot of other purposes too.
Old 30th January 2013, 08:14 PM   #430
I use this one with good results all the time :Digital-Multimeter/RLC-Meter VC88C | ELV-Elektronik
SB Acoustics Satori MonitorHide this!Advertise here!
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 03:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright ©1999-2017 diyAudio
