Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
SB Acoustics Satori Monitor
Old 27th September 2012, 11:01 PM   #21
tapehead ted is offline tapehead ted  United States
I really freaked out an experienced CNC operator with a cab that was, well it was a bit more involved than this one actually- compound angles are frequently terrifying even for quite experienced woodworkers, even with CNC machines!
What an awesome shape- I love it.
Old 27th September 2012, 11:05 PM   #22
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
It should be very stable and i find it logical. Thanks that you like it.
Old 27th September 2012, 11:11 PM   #23
Holger Barske is offline Holger Barske  Germany
Holger Barske's Avatar
Given the lengths of the edges, that can't be covered with a plain sheet. You would have to bend it.
Best regards: Holger
www.holgerbarske.com
Old 27th September 2012, 11:51 PM   #24
Yes, a plain single sheet is nearly impossible. Strange, at first i thought it could be done.
Usually ideas like that come to me in the morning when i wake up. Is it so bad that i even design in my dreams ?
Old 28th September 2012, 12:01 AM   #25
That's a logical extension to "carpe diem"
Old 28th September 2012, 12:41 AM   #26
Some years ago i designed the Sonics Aquilla that has also a slanted baffle that got more narrow to the top. Here the sides are bend so Holger is right.I called that "Butterfly".
Old 28th September 2012, 11:18 PM   #27
Is "the Butterfly" a transmission line? Is the taper part of that design approach too?
Old 29th September 2012, 12:29 AM   #28
No, it is a bass reflex, tube to the back. I thought that an inwards bend is more stable to inside pressure then the more usual outside bend like popularized by Sonus Faber.
Like a water dam that is bend against the water. The cabinet gets more narrow to the top and is angled by 7. That gives a measure of delay alignment and reduces diffraction effects.
Old 29th September 2012, 01:42 AM   #29
Why doesn't it act as an organ pipe? Or does it (it must, right?) and you're compensating for that somehow? I've been trying to make a tall bass reflex like that and coming to terms with the organ pipe issues, in theory, anyway...
I just now noticed the curved wood. Wow! I'd think they're would be a couple hot spots on either side where the convex surface focuses the sound at some frequency or another.
Old 29th September 2012, 08:56 AM   #30
The Aquilla is vertically divided into three damped chamber so the vertical resonance is suppressed. The cabinets have being manufactured by Hornslet in Denmark. They have a patent on bended or curved cabinets. Actually they are not easy to manufacture.
SB Acoustics Satori MonitorHide this!Advertise here!
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 04:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 01:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 01:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 11:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 09:15 AM
Copyright ©1999-2017 diyAudio
