SB Acoustics Satori Monitor SB Acoustics Satori Monitor - Page 20 - diyAudio
Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 14th October 2012, 08:25 AM   #191
gornir is offline gornir  Sweden
gornir's Avatar
Originally Posted by 5th element View Post
Scanspeak do have the 6640 though, their other Beryllium dome and this doesn't have anywhere near as much droop, its breakup is also less severe too.
http://www.scan-speak.dk/datasheet/pdf/d3004-664000.pdf
This driver has exceptional distortion performance as measured by others and I can't really see any reason why you'd pick the new scan tweeter over this one.
Perhaps and hopefully it's cheaper than the super expensive 6640?
/Göran
Author of the "AudioExcite Loudspeaker Design" website & Technical Consultant for HULGICHAUDIO
http://www.audioexcite.com http://www.hulgichaudio.com.au/
Old 14th October 2012, 12:38 PM   #192
tvrgeek is offline tvrgeek  United States
Originally Posted by Joachim Gerhard View Post
The new Scan-Speak Beryllium has a rather big diameter front plate that also works a bit like a waveguide. So we see also the effect of the front plate. After EQ it can be rarther flat and has advantages off axis.
"After EQ" Well, maybe it is just me, but one of the things I expect when one jumps this high in the price line is drivers should get easier to use. The extra money should go to resolving the various issues. At the very least, they should provide sufficient application notes. Look at the information provided for a $.50 op-amp vs. a $500 tweeter. Something is not right here.
Old 14th October 2012, 01:08 PM   #193
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
This is not a tread about hard domes anyway. I put on this brand new information because i thought you guys are interested in what the few quality companies are planning.
It looks like that they have not given up to move forward instead of making ever cheeper parts.
Old 14th October 2012, 01:40 PM   #194
So, how easy is the TW29 to use. That is really what we are waiting for. It is not even in the catalogs here yet.
Old 14th October 2012, 01:51 PM   #195
I will build test cabinets next week. From the measurements i do not expect any bad surprises.
Old 14th October 2012, 01:58 PM   #196
Here is a PDF from the SB website
Old 14th October 2012, 02:07 PM   #197
Found that, and one supplier on the continent, 120 eur. Not too bad.
Old 14th October 2012, 02:18 PM   #198
5th element is offline 5th element  United Kingdom
5th element's Avatar
Sometimes you do expect things to get easier when you pay more for drivers, but this isn't necessarily the case. As Joachim pointed out, soft domes going through controlled breakup helps to maintain their frequency response high up in frequency, this also helps maintain the off axis response. Metal dome tweeters usually come with a phase shield that helps to correct for these problems. The Scan BE domes and the SEAS diamond don't have phase shields so the off axis falls faster then your standard soft dome.
The same can be true of woofers too, where the cheap driver has a high inductance. This higher inductance causes the top end to droop slightly and it can make the cheaper driver seem easier to work with as it helps to keep the response flat and to lessen the visual impact of any issues at breakup. This is why it isn't uncommon to see very expensive drivers, with their super low inductance motors, having rising responses as frequency increases. You could say that it's a lot easier to design a cheap driver then it is to design an expensive one, because the expectations are high and the driver will be pulled to bits by the DIY community, you really do have to make sure that everything is correctly designed. It isn't a surprise that the Satori took a long time to develop when you see how well behaved the cone is, how flat it's on axis, along with the very low inductance motor.
Now the new Scan BE dome is a bit of an enigma, if scan had chosen to really shape the larger front plate into a proper wave-guide, rather then the very shallow affair they chose, then this would have helped significantly in maintaining its off axis response (just like in the SEAS DXT), whilst making the integration and directivity match to woofers even easier.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 14th October 2012, 02:20 PM   #199
No that isn't so bad, it was a good design choice to keep the magnet ferrite imo as neo would only raised the price unnecessarily.
Old 14th October 2012, 03:07 PM   #200
Yes, i wanted to talk about the possibility of a phase plate too to extend the range of a hard dome. SB makes a hard dome too that has a phase plate and the dome is shaped in a way to stiffen it a bit. I think the idea came because one of the designers of the old Scan-Seak hard dome has a father that had a car repair shop. He uses a chisel to repair bumps in the metal of a crashed car. After many years of use the top of the chisel goes into a certain shape that looks a bit like the sharper side of an egg, at least that is the story told to me.
SB Acoustics Satori MonitorHide this!Advertise here!
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 03:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 12:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 12:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 10:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 08:15 AM
Copyright ©1999-2017 diyAudio
