Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
SB Acoustics Satori Monitor
Old 13th October 2012, 05:05 AM   #181
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Here is an easy to understand poster about the major sources of distortion in a speaker.
Study it carefully and then we are talking...
http://www.klippel.de/fileadmin/klip...ity_Poster.pdf
Old 13th October 2012, 08:33 PM   #182
tvrgeek is offline tvrgeek  United States
"Easy" Always a warning! There is a lot to take in there. It does not show anything about how the motor structure does not produce a uniform field in the gap and the various non-linearity that causes, or how one can use one non-linearity to counter another. Motors are complicated. It makes you wonder how speakers are as good as they are and it does give you more respect for the designers of above par drivers. This will take more than casual reading.
Paul Klipsh was well known for saying distortion and efficiency were inversely proportional. This poster would tend to say otherwise for the motor. Obviously, the efficiency with which a driver is coupled to the air will help as it reduces the displacement for a given SPL, and this shows why that is a big advantage. Unfortunately, high efficiency horns have their own set of added distortions.
A comment was made about different magnet material and how that could effect distortion. I would have thought that a given flux was a given flux. What makes the difference? I have also seen several newer drivers using a set of slugs for magnets instead of a ring. Is this just for ease of manufacturing or is there some actual difference in how the motor works.
Another thread mentioned adding an electoral short between the front and rear pole pieces reduced distortion. I have never seen that done, so I would be skeptical.
I had not heard of Kipple. Thanks.
Old 13th October 2012, 08:50 PM   #183
Is not the case for a beryllium dome that the mass is so small, that in the upper reaches it is no higher than a soft dome that has decoupled regions? I also remember when I dealt with beryllium tape drive capstan wheels, it was very non-resonant compared to the magnesium wheels. When you set one down on a desk, it has less ring to it and it was higher in frequency. On the other hand, are the voice coil, former, and glue not so much heavier than the dome that the mass is not really important?
Old 13th October 2012, 09:13 PM   #184
5th element is offline 5th element  United Kingdom
5th element's Avatar
That diamond dome from SEAS is interesting. Hopefully SEAS will have improved their motor design so that it can compete with the Scans in non linear distortion.
What the hell are you screamin' for? Every five minutes there's a bomb or somethin'! I'm leavin! bzzzz! Now with website! www.5een.co.uk under construction.
Old 13th October 2012, 09:15 PM   #185
I found the problem with the SB29. It is the thin plastic back chamber. I'll post the pictures in the multi-way forum.
Old 13th October 2012, 10:26 PM   #186
Yes, making drivers is still a "black art". The Satori driver started life many years agao where the main designer told me that he is working on a reference driver and he will be ready soon. Now it is here, 4 years later. I do not want to know how many prototypes have being made until this result came out.
Yes, some ring radiators have poor mechanics cheep plastic parts, resonant chambers, etc. I mentioned that.
The published results from the SEAS diamond and the Scan-Speak beryllium show my point. They are less extended in the treble because they do not decouple. In theory they have an advantage in distortion though. That is the old discussion if a hard, medium or soft membrane should be used. The soft dome guys claim sweeter and more extended sound and the hard dome guys think that piston movement is the ticket. i made good speakers with both technologies.
I have made measurements with the same drivers that used different magnet materials.
I found differences in the distortion of the current . I will look if i can find the measurements and then i post them.
Old 13th October 2012, 10:37 PM   #187
Scanspeak do have the 6640 though, their other Beryllium dome and this doesn't have anywhere near as much droop, its breakup is also less severe too.
http://www.scan-speak.dk/datasheet/pdf/d3004-664000.pdf
This driver has exceptional distortion performance as measured by others and I can't really see any reason why you'd pick the new scan tweeter over this one.
Old 13th October 2012, 10:57 PM   #188
On paper, I would agree. I guess hearing is believing. Still, out of my price range. A standard air-circ is about my limit! Not sure which one to try though. d3004/662000 maybe.
Old 13th October 2012, 11:53 PM   #189
The new Scan-Speak Beryllium has a rather big diameter front plate that also works a bit like a waveguide. So we see also the effect of the front plate. After EQ it can be rarther flat and has advantages off axis.
Old 14th October 2012, 12:30 AM   #190
If it's acting like a wave-guide then its effect is only very minimal and hardly worth the extra diameter. The original revelator was much better in this regard.
SB Acoustics Satori MonitorHide this!Advertise here!
SB Acoustics 3 ways cosmindaniel12 Multi-Way 39 2nd August 2014 04:30 AM
More T/S specs needed for SB Acoustics mcmahon48 Multi-Way 2 15th August 2010 01:34 PM
All SB Acoustics MTM ?? Andy G Multi-Way 12 26th September 2009 01:35 PM
Anybody familiar with SB Acoustics zimjj Multi-Way 0 13th March 2009 11:30 PM
SB Acoustics... The stuff looks good sardonx Multi-Way 20 16th February 2008 09:15 AM
Copyright ©1999-2017 diyAudio
