Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
FS:	My new design: CM6631 24bit/192khz USB to Coaxial and Optical fiber
Old 25th February 2013, 02:00 AM   #11
Astrax is offline Astrax  Denmark
I'm a newbie here
Originally Posted by UrSv View Post
I second that. A CM6631 board with both input and output would be great.
Agree
It will be the perfect external USB sound card for my laptop to run my DIY sdr station.
24bit/192Khz line I/O to decode the I/Q signal is a must and I'm convinced there are 1000 out there looking for a such board.
Astrax
Old 18th March 2013, 11:12 PM   #12
vinodt1347 is offline vinodt1347  United Kingdom
Default how do you unistall W7 driver?
Iam not able to use the supplied driver. It gives an error message saying Please connect the CMEDIA Audio device..
Rgds
Originally Posted by colinyal View Post
I sorted this by uninstalling driver w7 installed & installing driver from vendor.
I now have 4 of these units & they are all fine (3 with 88k & 176k firmware).
Always you have to uninstall driver w7 installs & use vendor driver, this is weakness in w7 (XP gives you option to install from location of your choice, which is what you want !).
Also you have to open device properties and tick sample rates supported.
Also if you use different usb socket you need to install drivers again.
Old 22nd March 2013, 04:52 AM   #13
maynard999 is offline maynard999  United States
I installed the new CM6631 board today. Loaded the drivers and it plays great. I desoldered the LED and hooked up the wires to the case USB LED.
I can't figure out the LED though. The old USB board only lit the LED when the computer was plugged in. This one comes on at power up. Is there a second spot to wire in the case USB LED? If there is I can't find it.
Old 26th June 2013, 10:05 AM   #14
rmarin is offline rmarin
Hi Mr. Weiliang.
I have bought 2 DAC7 with CM6631 USB modules fom minishow seller (user RAZOR2000SHOP). These units work fine but I have a problem with CM6631 when I try to play wave file in 192khz 24 bits resolution. The sound is good but I have also several scratches noise (non periodic). I'm using a TOSHIBA TECRA pc with WINDOWS7 but the problem is existing also with other computers.
Someone told me that is necessary a new firmware. If this is true could yuo send me the firmware, the installation tool (for WIN7) and the instructions how to do it?
My emai is: roberto.marin@mail.wind.it
Thank you in advance.
R. Marin.
FS:	My new design: CM6631 24bit/192khz USB to Coaxial and Optical fiberHide this!Advertise here!
My new design: CM6631 24bit/192khz USB to Coaxial and Optical fiber weiliang Vendor's Bazaar 31 3rd August 2014 06:27 PM
Hi-resolution source 192KHz 24bit (USB to Analog) audiodesign Digital Source 22 25th December 2011 09:29 PM
Cleo: End to End 24bit 192khz USB DAC with tube output bcherry DIY HiFi Supply 7 4th July 2010 12:15 AM
Hiface USB -> I2S 24bit/192Khz audiodesign Group Buys 367 26th May 2010 01:00 PM
FS: 24bit/192kHz dac Tekko Swap Meet 1 17th June 2009 09:27 PM
