Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 22nd November 2012, 11:33 AM   #891
Alcaudon is offline Alcaudon  Spain
Not sure if I'm still on time, but I edited the spreadsheet to add another board to GB3 (45 units right now, only 15 more to go).
Old 22nd November 2012, 12:05 PM   #892
stamatiski is offline stamatiski  Greece
Pls add 2 units for me
Old 22nd November 2012, 12:54 PM   #893
bcmbob is offline bcmbob  United States
Originally Posted by Jackal29a View Post
@Supra, were you using a B-III?
My findigs were the same.
Brings up the question - is anyone getting good results with non-Buffalo DACs?
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 22nd November 2012, 01:17 PM   #894
supra is offline supra  Australia
Another question- is anyone getting proper DSD operation, apart from GLT and his very complex foobar implementation?
Are there faulty units coming into the market?
Old 22nd November 2012, 01:18 PM   #895
smanz is offline smanz  Spain
Originally Posted by supra View Post
Doesn't work for me-one channel of DSD works fine, the other channel is just noise. Works fine with any PCM, but new driver/firmware doesn't make DSD work for me. I suspect it might be a faulty board.
Don't know what to do now, tried everything but no L&R DSD which is why I bought this device.
Try to modify buffer length. In my case, works fine with little lenght.
Old 22nd November 2012, 01:20 PM   #896
Jackal29a is offline Jackal29a  Spain
DSD worked fine with standard Amanero and BIII before last firmware and drivers update, there only was the reversed channels problem but no noise.
Old 22nd November 2012, 01:21 PM   #897
azouts is offline azouts  Greece
I added myself to the list for one module. Thanks
Old 22nd November 2012, 01:32 PM   #898
dickiegeorge is offline dickiegeorge  United Kingdom
DSD is working fine for me now using the setup detailed on glt's blog (great info - thanks) using current driver (version 1.056) and Buff2.
Supra - have you tried updating the firmware (Amanero Technologies)?
Old 22nd November 2012, 01:40 PM   #899
Those who still have DSD working, did you update both or just driver/firm?
Since both driver and firmware were updated in the system I tested I have no way of knowing which one broke DSD play or if it is both not playing along.
Old 22nd November 2012, 01:47 PM   #900
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
do the drivers work with Windows 8?
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
