Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 19th November 2012, 05:12 AM   #851
stamatiski is offline stamatiski  Greece
An even newer version will be added today fixing the "first playback wrong channel" bug!
Old 19th November 2012, 08:33 AM   #852
dickiegeorge is offline dickiegeorge  United Kingdom
Thanks to Domenico for the fix - KS seems to be solid in Foobar now.
Originally Posted by stamatiski View Post
Using Kernel Streaming in my system all streams including DSD just play straightforward with no other intervention.
Using Amanero with KS and deploying my tri-amplification the sound seems to be sooo direct that is frightening.. wish I could share this sound with you all
How do you get DSD to play over KS? I had thought that ASIO was needed for this, which is what I've been trying using ASIO4All.
Old 19th November 2012, 08:55 AM   #853
Install foo-KS and try to play any DSD file. It works as a charm!
The DSD indication should come up at the bottom left confirming the DSD playback.
At least thats what happens to my system.
Old 19th November 2012, 09:41 AM   #854
Thanks for the response Stamatiski, but I must be missing something
Do you mean "foo-out-KS" ? I have this installed, along with the foobar SACD plugin, but need to use ASIO for playback. Selecting KS results in silence from DSD files.
EDIT:
Just installed "foo input dsdiff" and removed the SCAD component and it all works lovely now - no horrible ASIO4All kludge .
Old 19th November 2012, 10:30 AM   #855
Spread the news!!
All we need is KS as the most simple most functional and purest method in Foobar.
May be we could push things for a foo-out-KS update (if needed) since it has not been updated for 6 years now
Old 19th November 2012, 10:48 AM   #856
Jackal29a is offline Jackal29a  Spain
"foo input dsdiff" only outputs PCM. You can achive the same but better SQ configuring SACD plugin to output PCM.
Old 19th November 2012, 10:57 AM   #857
@jackal29a
obviously we are talking about KS as an OUTPUT option. The "foo input dsdiff" as its name states is an INPUT decoder (necessary though to do the job) and NOT an OUTPUT option.
Old 19th November 2012, 11:25 AM   #858
@jackal29a
I know, I was addressing dickiegeorge's comment. The only way so far to get true DSD from the combo384 in Foobar is using the "kludgy" route, using DSDIFF one only can get PCM independent of output mode used. No probs with JRiver using WASAPI or KS though.
DSD is not possible in Foobar using KS or WASAPI due to DSP and Volume stages of the player not being ready for DoP and treating the signal as regular PCM. When asked about this they said they have no intention of changing it. I guess they are not interested in DSD.
As I'm on W7 I use WASAPI Event as output.
Old 19th November 2012, 11:27 AM   #859
Yves Smolders is offline Yves Smolders  Belgium
Can someone confirm that this USB interface is async?
I'm not sure, even after searching the thread for "async"
If yes, it would be a massive upgrade for my DAC (Wyred4sound DAC-2)
Thanks!
Old 19th November 2012, 11:49 AM   #860
Jackal29a thanks for the info.
It makes sense that "foo input dsdiff" is converting the files into PCM which is then handled natively by the KS output. I don't have an indicator for PCM / DSD on my Buffalo DAC (only S/R) so I can't see what's going on. I need to hook up my Arduino for that.
I did feel that DSD played over KS output sounded a little different from ASIO - this would explain why.
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
