Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 17th November 2012, 04:59 PM   #831
bcmbob is offline bcmbob  United States
It would be nice to hear a couple reviews of the I2s sound quality as compared to s/pdif.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 17th November 2012, 05:09 PM   #832
smanz is offline smanz  Spain
Originally Posted by glt View Post
Really? I had a suspicion but couldn't tell since one of the amps in my setup is out of commission and was listening with one channel. Seems the way PCM channels and DSD channels are configured are "standard". Perhaps, Amanero can add the option of swapping DSD channels in firmware.
Yes, itīs really. Direct connexion Amanero-Buffalo swap DSD channels over PCM. In other hand of things, I modified your Hifiduino code. Now, when detect DSD signal, automatically change to specific input in order to load correct configuration. Also, if the selected input is DSD, and PCM signal is detected, automatically switches to the correct input.
Old 17th November 2012, 05:44 PM   #833
Telstar is offline Telstar  Italy
If you google around, u will find a few. The difference is big.
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 17th November 2012, 06:04 PM   #834
2A3SET is offline 2A3SET  Canada
That's cut from FR4, used to do when was kid, good to pick up again.
Originally Posted by qusp View Post
fair enough, been there, as is thats probably the most prone thing to issues as there is no return for the individual i2s signals. lots of work in that cute little 'PCB' is that just cladded board youve cut, or protoboard youve added foil to?
Old 17th November 2012, 06:08 PM   #835
glt is offline glt  United States
Originally Posted by smanz View Post
Is correct, but when play DSD, the channels are swapped over PCM.
My solution is to swap PCM channels in the player. I use Foobar, and is not posible software swap for DSD channels.
I used a PCM left/right track and converted to DSD with the foobar sacd plug-in and was able to swap the channels with the "custom channel mapping"
www.hifiduino.wordpress.com
Old 17th November 2012, 06:16 PM   #836
Thanks, I'm aware of the general opinion. Was just hoping to get some reports on this specific module.
Bob M.
Old 17th November 2012, 07:02 PM   #837
I tried swap DSD channles of the foo-dsd-asio in Asio Virtual Device Editor but donīt work. Changes no take effect.
This is the reason to swap PCM channels. And of course, swap RCA or XLR audio connectors.
Old 17th November 2012, 08:28 PM   #838
supra is offline supra  Australia
Thanks to all.
Old 17th November 2012, 09:17 PM   #839
I was able to swap the DSD channels: foobar Configuration for DSD (With Amanero Interface & Buffalo DAC) H i F i D U I N O
Old 18th November 2012, 02:58 AM   #840
stamatiski is offline stamatiski  Greece
I am using amanero to signal with I2S a sabre 9018 board. I succesfully installed the latest firmware using Jesper.
Some strange things noticed though when auditioning with Foobar 2000.
1. When in kernel streaming on 32bit channels (menaning L,R audio channels)are inverted!! switch to 24 bit.. channels ok!
2.When in wasapi (event or pushed mode either) the opposite applies; 32bit channels ok... 24bit channels inverted!!!
3.Also when in Kernel Streaming (which generally speaking I prefer) after the first playback the driver option dissapears from foobar/output settings even though the device is playing as normal. Amanero KS dissapears from the selection panel to appear again only when OS is restarted!!
Anyone else noticed something like this?
I unistalled - reinstalled several times the device. Always the same...
I managed to get correct channel distribution straight with absolutely no mods when using ASIO4ALL though.
That tells me there could be a problem with Amanero win7 drivers.
Any thoughts?
And another question; has anyone tried to signal a 7.1 adjusted sabre using Amanero for multichannel use?
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
