Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 11th October 2012, 01:17 PM   #521
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by syklab View Post
How would you compare the NVE with the TI ISO7240 or AD Adum3440?
with their datasheets =)
that and the fact that those 2 were chosen by Ian as the best options for the i2s fifo buffer isolation board proto with good results.
Old 13th October 2012, 12:16 PM   #522
necplusultra is offline necplusultra  Canada
Does anybody know where to source an isolator adapter pcb?
If not, would a group buy be feasible?
It seems to be a simple circuit even to include a LDO regulator circuit for the output portion.
regards.
Old 13th October 2012, 12:21 PM   #523
syklab is offline syklab  United States
Interested in a few as well.
Old 13th October 2012, 01:52 PM   #524
mavsan is offline mavsan  United States
I added my name to the GB list.
Old 14th October 2012, 04:55 AM   #525
Boomer2 is offline Boomer2  Canada
+1
Old 14th October 2012, 07:50 PM   #526
neskor is offline neskor  Serbia
Old 14th October 2012, 10:41 PM   #527
dsdjoy is offline dsdjoy  Germany
USB to I2S 384Khz - DSD Converter USB to I2S 384Khz - DSD Converter
Here is a good comparison of different isolators:
Which Digital Isolators for I2S? …or NOT H i F i D U I N O
Old 15th October 2012, 02:37 AM   #528
2A3SET is offline 2A3SET  Canada
Default BCK from XO directly
Just a quick test, SCK/MCLK from XO directly (PIN 43/44 tied together) sounds better than from the standard CPLD output. Anyone else tried?
Old 15th October 2012, 03:35 AM   #529
qusp's Avatar
thanks. So those 2 I mentioned were the best specced back then too
Old 15th October 2012, 07:26 PM   #530
Default Reclocking the BCK
After improvement of getting MCLK from XO instead of using standard PIN 6, I tried reclocking the BCK with same MCLK and the improvement is very positive. Right now I tied PIN43/44 on CPLD together, fed MCLK to reclocker and DAC with 2K resistor. The reclocker is 74AUC1G74 D-type flip-flop at 2.5V (power pull from 3.3V with 330ohm in series). Left side is PCM5102 DAC.
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright ©1999-2017 diyAudio
