Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 9th October 2012, 01:57 PM   #501
qusp is offline qusp  Australia
qusp's Avatar
Originally Posted by orpheus View Post
Domenico from Amanero PM'd me about my problems, and sent me this link to upgrade my firmware. I haven't done extensive testing, but the "crackles" in the sound with OSX are gone on the first try. I don't think that this has been posted in this thread, and I can't find a link to it on the Amanero homepage.
Amanero Technologies
You have to use Windows to update the firmware.
-Aaron.
great, no win machine in the house and i'm not going to install win on my mac just so I can update... guess it stays uninstalled....maybe one day...
Old 9th October 2012, 02:06 PM   #502
bcmbob is offline bcmbob  United States
You are probably already aware, but Parallels creates a perfect Win 7 virtual pc with real hooks to the hardware on an OSX box.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 9th October 2012, 02:11 PM   #503
shoom is offline shoom  Europe
Hi qusp
it would be a shame to waste it. how about someone you know with Win?
if not i may know someone in Brisbane you could try
just a thought
Old 9th October 2012, 02:32 PM   #504
qusp's Avatar
Originally Posted by shoom View Post
Hi qusp
just a thought
thanks, yeah thought of both those, probably will go with the second as the first is just as much of a pita as installing win, because you still have to install win. its not a high priority, I already have better USB->PCM/i2s hardware, I only got for DSD tests and have bugger all DSD music, so its no big deal, but its annoying.
cant argue with the pricing if I can make it work, i'll get around to it, but its slipped in the queue
wondering how this stuff made it through beta.... guess the right lights lit up. sims and models have a lot to answer for
Old 9th October 2012, 03:13 PM   #505
I missed the first GB by a whisker but Iím planning on using it for a battery powered portable DAC at some point. As you say for the price it looks pretty good.
Beta
I guess with new products it can be difficult to get things just right with so many OS/media players etc. to cater for. Some seem to have had problems but thatís par for the course maybe. Iím not sure that the FW update was intended to be in the public domain and maybe just given to individuals if needed. Just a guess on that but I donít know for sure.
No DSD this end either Iím planning I2S only for now.
For hardware I have another card also.
It would have been nice to have just a little more feedback from the folks that have the Almanero card up and running.
Implementation and subjective thoughts maybe helpful to others.
Hope you find a Win machine soon
Sunshine State
Mmmmmmmmmmmmmm Yes please
Old 9th October 2012, 03:59 PM   #506
Agreed, I'm assuming the silence from the Linux folks means a smoother implementation - but not sure. In anticipation, I now have a Ubuntu Studio full install and a working USB boot of another distro. Don't have the card yet but it would be great to hear more from the Linux users.
Bob M.
Old 9th October 2012, 04:29 PM   #507
korben69 is offline korben69  France
korben69, with your success, can you give a description of the quality/nature of the sound you are hearing?
Can't really comment as I've got a simple run for this, testing only
My system is as follow :
- Preamp : UGS Balanced/Unbalanced
- Mini-A Balanced (Mid/High passive filter)
- UCD180ST (LM4562 modded) Balanced (Bass passive filter)
- Balanced TP Opus DAC WM8740 + TP SPDIF receiver + TP USB
- SE Subbu's DAC V2.6 (WM8804 SPDIF embeded receiver)
- SE USB DAC's PCM 270x
Playing same 24/96 FLAC files, my subjective ranking result is :
1 - Amanero's stick + Opus WM8741 & SE Subbu's DAC 2.6
2 - Opus WM8741 + SPDIF
3 - Others USB DAC PCM 270x
I can't play 24/96 in source format using Subbu's DAC V2.6 and WM8741 (First is configured in SPDIF mode, the second is boxed...)
Wiring is a "workbench" state, so it can really be inproved and shorten.
I've tested Amanero's stick to se if my WM8741 hardware mode was correct using I2S stream... and it is
What I can say is that the "audible audio band" seems to be larger and deeper, very close to what I've got with 16/44 files using DAC V2.6/SPDIF.
Very difficult to compare SE with BAL and, 16/44(48 resampled in Foobar) vs 24/96.
More to come with Balanced I2S Subbu's DAC V3.
This time it will be more accurate
Old 9th October 2012, 04:32 PM   #508
Bob M.
Old 9th October 2012, 08:22 PM   #509
orpheus is offline orpheus  United States
Originally Posted by Jackal29a View Post
HAL, Maxim (foo_SACD_input creator) has suggested using ASIO4All as a proxy (I used latest beta 2.11). I've just checked it and it does indeed work (Pin7 = 3.3V).
Double proxying is certainly not the most elegant solution but it can do until Domenico releases the true ASIO drivers. Wonder if he'll go for DSD over ASIO or he'll stick to DoP.
For this to work you need to confiure foo_dsd_asio as output device. foo_dsd_asio has to be configured to send the signal to ASIO4All who in turn has to be set up to send its output to the Amanero drivers.
Which pin is it that you are testing? Is it DSDOE?
Thanks,
Aaron
Old 9th October 2012, 08:37 PM   #510
Jackal29a is offline Jackal29a  Spain
Thanks,
Aaron
Yes.
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
