Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 8th October 2012, 12:29 PM   #491
Jackal29a is offline Jackal29a  Spain
Will check the DSD pin on my setup and rsport back.
Old 8th October 2012, 12:31 PM   #492
HAL2010 is offline HAL2010  United States
Thanks!
Old 8th October 2012, 01:48 PM   #493
HAL, you are absolutely correct. 0V on DSD pin with Foobar in either WASAPI or KS mode. Tried with JRiver (WASAPI Event + DoP bitstream) and I do get 3.3V on the same pin.
I've posted WASAPI/KS compatibility as feature request on the plugin developer's site, hope he fixes it or Domenico releases the ASIO drivers soon, or even better both to have a wider choice
Old 8th October 2012, 02:16 PM   #494
Great! We have repeatability!
The HQPlayer is a free demo version for 30 days. Hope that the Foobar2000 change or the ASIO driver comes out in that time!
If not will have to give JRiver a try.
Old 8th October 2012, 03:37 PM   #495
orpheus is offline orpheus  United States
Domenico from Amanero PM'd me about my problems, and sent me this link to upgrade my firmware. I haven't done extensive testing, but the "crackles" in the sound with OSX are gone on the first try. I don't think that this has been posted in this thread, and I can't find a link to it on the Amanero homepage.
Amanero Technologies
You have to use Windows to update the firmware.
-Aaron.
Old 8th October 2012, 06:36 PM   #496
Johnwkkwan is offline Johnwkkwan  Hong Kong
Hi Amanero,
I just put my name in list for 4 sets.
https://docs.google.com/spreadsheet/...wYS1EcXc#gid=0
Thanks.
John
Old 9th October 2012, 08:57 AM   #497
HAL, Maxim (foo_SACD_input creator) has suggested using ASIO4All as a proxy (I used latest beta 2.11). I've just checked it and it does indeed work (Pin7 = 3.3V).
Double proxying is certainly not the most elegant solution but it can do until Domenico releases the true ASIO drivers. Wonder if he'll go for DSD over ASIO or he'll stick to DoP.
For this to work you need to confiure foo_dsd_asio as output device. foo_dsd_asio has to be configured to send the signal to ASIO4All who in turn has to be set up to send its output to the Amanero drivers.
Old 9th October 2012, 12:32 PM   #498
daltvi is offline daltvi
Default OEM COMBO
Hi Amanero,
I put my name in list for 1 sets. My nick name "Vegasi"
Thanks.
Old 9th October 2012, 12:40 PM   #499
korben69 is offline korben69  France
Originally Posted by Jackal29a View Post
BTW, how did you connect the wires from the Amanero to the Opus?
Was it like this?:
Pin3 (DATA/DSD1) -> R (OSRD/DSDR)
Pin4 (CLK/DSDCLK) -> C (BCKIN)
Pin5 (FSCLK/DSD2) -> L (LRCL/DSDL)
Any GND pin -> G (GND)
Hi
Got my Opus V1 with WM8741 (yes!) working with Amanero's stick :
Pin3 (DATA/DSD1) -> DIN
Pin4 (CLK/DSDCLK) -> BCK
Pin5 (FSCLK/DSD2) -> LRCK
Pin6 MCLK -> SCK
Pin8 GND -> GND
Opus configured in hardware mode, 24bits I2S.
Foobar - WASAPI 3 - Win7 Pro 64bits
Old 9th October 2012, 01:16 PM   #500
bcmbob is offline bcmbob  United States
korben69, with your success, can you give a description of the quality/nature of the sound you are hearing?
Bob M.
"Arrange Whatever Pieces Come Your Way."
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
