Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 2nd October 2012, 10:39 AM   #461
syklab is offline syklab  United States
Originally Posted by shoom View Post
Yes I caught Almanero’s post in my email box and came over to see it in the flesh so to speak.
Maybe he was swept away in the stampede of eager customers.
Hi Skylab
A picture of how you connected Subbu’s DAC to Almanero board may help find the problem more quickly.
Yellow is Data, Green is BCLK, Blue is FSCLK and Pink is ground. The Subbu DACX is working fine with S/pdif input.
Old 2nd October 2012, 11:05 AM   #462
korben69 is offline korben69  France
Hi skylab
Can't see if you have removed R7-R8-R9...
When doing this you "cut" I2S signals from WM8804.
(R7 : BCK - R8 : LRCK - R9 : SDI for ES9023)
Worth a try
Old 2nd October 2012, 11:26 AM   #463
shoom is offline shoom  Europe
Originally Posted by korben69 View Post
Hi skylab
Worth a try
Hi Korben
yes that's just what i was thinking as it wonít work with those resistors in place.
Skylab
just out of interest what OS and audio player are you using? have you checked the OP settings on your audio player? Itís easy to overlook those things.
Been there done that
It may also be worth doing a board to board continuity check just to make sure that your connections are nice and snug.
Old 2nd October 2012, 11:32 AM   #464
skylab "pins output" for I2S seem correctly placed to me.
But the R7/8/9 are used for WM8804 I2S and could interract...
Removing them is IMHO the way to go.
Config : Win7 64 bits + Foobar + Wasapi 3
OP settings on Foobar ? Please elaborate
Old 2nd October 2012, 11:56 AM   #465
I want to keep the resistor there so that I still can use s/Pdif if needed, guess that didn't work. I will build another dac without the WM8804 to test with the amanero (have 1 pcb left). I am running Win 7 pro 32bit with foobar2000 + DS amanero driver, didn't use wasapi.
Old 2nd October 2012, 12:06 PM   #466
That's exactly my position and configuration skylab.
I let my actual V2.6 DAC in SPDIF mode, it sounds very very good as it is.
Next one, DAC V3 will be done in I2S mode only, maybe BAL too.
I'm trying to make a WM8740 working with I2S using Amanero's stick.
It's an old Opus revision with jumpers... confusing to me
I'll give it a try soon, but I'm busy at this time.
From my last attempt, I strongly recommend the use of Gnd pin
Old 2nd October 2012, 12:33 PM   #467
I solder a connection pin to the ground connection from C20 which is recommended from another member.
Old 4th October 2012, 01:33 AM   #468
jacobthellamer is offline jacobthellamer  New Zealand
Put my name down for 1
Old 4th October 2012, 04:53 PM   #469
qusp is offline qusp  Australia
qusp's Avatar
Jake, the idea is that YOU put your own name down for one on the spreadsheet at googledocs
Old 4th October 2012, 06:53 PM   #470
I should have been clearer, 'I put my name down for one'
This is the correct sheet?
https://docs.google.com/spreadsheet/...wYS1EcXc#gid=0
Jake
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
