Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 27th September 2012, 07:52 AM   #401
jrobson is offline jrobson  South Africa
Hi I asked him some of the above questions.
For over 192Khz for now use kernel streaming, wait for ASIO to come, hopefully soon, they are working on it. WASAPI in J.River will only do 192Khz.
Old 27th September 2012, 09:24 AM   #402
Dimdim is online now Dimdim  Greece
Also put my name in for x1 piece.
BR,
Dimdim
Old 27th September 2012, 01:54 PM   #403
Ludomaniac is offline Ludomaniac  Norway
Send a message via MSN to Ludomaniac
I'm in...
Old 28th September 2012, 12:03 PM   #404
rsotirov is offline rsotirov  Canada
I added myself to the spreadsheet for one board.
Thanks, Amanero.
Roumen
Old 28th September 2012, 01:02 PM   #405
opc is offline opc  Canada
opc's Avatar
I also tried and failed to get bit-perfect operation under WASAPI and Win 7 the other day. Using the Audio Precision Bittest, direct I2S out to the AP, and connected to a Windows 7 PC using J River there doesn't seem to be any way to get bit-perfect reproduction.
Every other USB card I have tried with ASIO drivers (Musiland, XMOS, exaU2I) worked perfectly in this setup with an error rate of 0 even after several hours of running.
I'm starting to think most of the issues I'm seeing are related to the WASAPI implementation and not the Amanero card itself, which means I'm really crossing my fingers for good ASIO support under Windows 7. This WASAPI thing seems like a bit of a crock to me.
Owen
Old 28th September 2012, 01:11 PM   #406
necplusultra is offline necplusultra  Canada
Tried the board with my test setup.
Correct me if I'm wrong but this board does not have an ASIO driver.
Or does it?
Old 28th September 2012, 01:28 PM   #407
qusp is offline qusp  Australia
qusp's Avatar
Or does it?
no it doesnt, but as was just mentioned above, he is working on it. I was assured this before I put my name on the list
Old 28th September 2012, 02:19 PM   #408
MrSlim is offline MrSlim  Canada
Owen
Owen, Do you have a Linux(and/or Mac) setup you could test it with? I could provide the hardware if you are interested..
John
Old 28th September 2012, 02:21 PM   #409
bcmbob is offline bcmbob  United States
Can someone present a fairly simple explanation of how Linux and OSX avoid these difficulties? That's my understanding and please correct me if I'm not getting that correct.
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 28th September 2012, 02:29 PM   #410
Linux and OSX have USB 2.0 audio drivers built into the base OS(as long as the DAC or Transport manufacturer(Amanero in this case) adhere's to the driver standard).. No "special Sauce" needed. There are other tweaks (pulse audio vs ALSA, kernel tweaks(even Real Time Kernel replacements, which some people swear by) that "can" improve (according to some) the SQ even more, but it basically works out of the box.
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
