Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 6th September 2012, 08:18 AM   #231
Jackal29a is offline Jackal29a  Spain
Originally Posted by mvaldes View Post
I have a saved a copy of that excel sheet and I can see you was line 35 instead of Jackal29a that was line 32 (now empty)
Hope this help
Can you compare both lists to check if some one has "inserted" himeself in the middle of the queue instead of at the end?
Old 6th September 2012, 08:57 AM   #232
mvaldes is offline mvaldes  Italy
I've checked and all the other lines are ok
Michele
Old 6th September 2012, 02:07 PM   #233
NicMac is offline NicMac  Italy
NicMac's Avatar
Default While waiting......
What is the module's power requirement?
I read on glt's blog that the USB power is being filtered, but I also see a 3V3 header
So is it USB-powered, external powered, or both? Selectable?
If external power is required what is the current draw?
From one of the YouTube videos of the device, I see a drop down menu in the Mac OS control panel for the device where the sample rate is being chosen....
Does that mean that the I2S output sample rate is chosen here, independently of the original sample rate of the file?
Grazie,
Nic
Old 6th September 2012, 02:19 PM   #234
amanero is offline amanero  Italy
Grazie,
Nic
The module is self powered (USB VBUS) in the output connector you have 3.3V from the LDO. For example you can use this pin to know when the cable is plugged.
If you don't like the USB VBUS supply, you can remove the LDO and power the module directly from the 3.3V pin present in the output connector.
About the sample rate menu: In MacOS by default the sample rate is fixed. Audio Midi Setup let you choose the default sample rate. If you want a variable sample rate you need to use a dedicated player.
Old 6th September 2012, 02:45 PM   #235
NicMac's Avatar
Thanks!
What is the power consumption from the USB VBUS?
Is the relevant LDO the SOT device seen just below the silkscreen R6 label on the photo you posted?
What is the P3 header for?
What are the DSDOE and TMD.C headers for?
Are these (and the MUTE header) pulled high or low when activated?
The device has an extremely simple interface so I guess I have now run out of questions
Nicolai
Old 6th September 2012, 02:56 PM   #236
Woodenhead is offline Woodenhead  United Kingdom
Hope this help
Hi Michele,
Thanks for confirming that it wasn't all a dream! Also to Domenico for confirming that I am still due a device.
So it was Jackal29a, eh? Sounds a shady character...
Will
Old 6th September 2012, 02:59 PM   #237
the power consumption is about 600 mW at max speed. LDO near R6 is the right one. P3 is used to erase the flash and force a firmware update via USB.
DSD_OE is 1 when a DSD stream is incoming.
The pin called Mute has been assigned to PIN 11 and is asserted to 1 when a sample rate change is incoming or when there is a stream format change DSD / I2S you can use this pin to avoid noise when the dsd is detected.
The pin 6 is the Master Clock MCLK 22,5792Mhz or 24.576Mhz.
TWC.D is an I2C bus, i m preparing a ConfigTool that let's the user configure Events in the module. For example you can assign I2C address and values to put in the I2C bus when the volume is changing or when a sample rate is changing. blah blah
Domenico
PS
For each package there is a note with output connector description.
Old 6th September 2012, 03:17 PM   #238
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Is it better to power the dsd converter externally, or is usb just fine?
Old 6th September 2012, 03:38 PM   #239
GuidoR is offline GuidoR  Italy
GuidoR's Avatar
The on-board LDOs are already of very good quality (low noise), but you are free to supply the board by an external supply (Shunt PS? Battery?) with a limited effort. Try by steps, but consider that the starting point is considerably good
Guido
Old 6th September 2012, 03:45 PM   #240
massimo is offline massimo  Italy
Better using an external raw supply rather then rely on the +5V incoming from your computer USB port IMO.
The question is: how can we do that? Should we cut the +5V track from the USB connector and connect the external PS there?
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
