Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 2nd October 2013, 02:19 PM   #1731
hannesie is offline hannesie  Netherlands
I am using it with Vortexbox (= Fedora 16, = Linux), and it runs without any problem.
Old 2nd October 2013, 07:04 PM   #1732
terranigma is offline terranigma
terranigma's Avatar
Can you adjust the volume?
Old 2nd October 2013, 11:43 PM   #1733
I am using the Amanero in combination with a Sabre 9016 DAC and that is in combination wirh a volumecontrol, that works perfect.
Old 4th October 2013, 12:18 AM   #1734
arginine is offline arginine
Hello,
I'm trying to power up the amanero board using external 5V regulated & linear PSU.
For that I make a custom USB (A-B) cable but unfortunatel the amanero module is not reconigized with this custom cable (DATA + and - from the raspberry pi and GND and 5v from the linear PSU)
Is there is one of you how manage to power the amanero bord NOT from 5V USB ??
F
Old 4th October 2013, 04:55 AM   #1735
luxury54 is offline luxury54  Romania
have you kept the GND refference also from the PC or just from the 5V linear PSU?
you must keep also the PC GND because D +/- is not recognized otherwise ... and keeping the (poluted) PC GND gives you NO benefit even if you use linear PSU
better install a ADuM USB isolator before the amanero (with 24/96khz limit) or if you want no sampling rate limit an I2S isolator after the amanero and that one (the isolated half) can be powered with great benefit from the linear PSU
== There are no limitations to the self except those you believe in ==
Old 4th October 2013, 08:00 AM   #1736
Hello luxury54,
The Amanero is connected to a raspberry pi.
I've tried different options:
GND from the the pi and GND from the linear PSU and in both cases the amanero is not recognized :-(
I tried with a "custom USB cable" and with a commercial cable where "I cut" the 5V and the GND.
ps: by using a standard commercial cable works perfectly (i.e. the amanero is powered from the USB of the pi)
I have the feeling that the problem may come from my linear PSU but if I check the voltages:
from the pi : 4.8 VDC
from the linear PSU : 5.0 VDC
... can't believe the difference of 0.2 V is causing the issue
My linear PSU
4 17UV Ultralow Noise DAC Power Supply Regulator 3 3V 5 5V 1AX4 | eBay
(source raspyfi : The best Raspberry Pi power supply - RaspyFi)
My setup (the picture is with a custom USB-AB cable for connecting the amanero and the legend is in french) but it's self speaking I guess:
https://www.dropbox.com/s/t05vh21h81l9f2q/Untitled.png
I would think that, somehow, the linear PSU is causing the problem but honestly I have no idea where and where I could investigate
Francis
Old 4th October 2013, 03:45 PM   #1737
rnacoustics is offline rnacoustics  Netherlands
Added myself to the list for 3 pcs
Old 7th October 2013, 10:23 PM   #1738
Marek is offline Marek  Poland
Amanero, is that possible to develop CPLD firmware which provide LL/LR, DL, DR and BCK signals insteed of I2S for R2R multibit DACs like PCM63, PCM1702/4, AD1865/2?
Old 8th October 2013, 06:39 AM   #1739
good question, I second that
Old 8th October 2013, 04:24 PM   #1740
SebastianL is offline SebastianL  Denmark
Default Which source?
Originally Posted by janos_904 View Post
Hi, Thanks to Merlin El Mago, who managed to do similar upgrade, I have made this trick, using Salas 1.1 BIB at 5V output. The already good skills of amanero board were elevated to a new level. Finally, I ended up of using just a 3,3V, which is connected to the 3,3 V outlet on the board (near to the I2S outputs). Also an advantage, that the quality of USB cable is less sensitive, because there is no 5V running on it. I have to say, this setup easily rivals the best CD transports. Congratulations to AMANERO and many thanks to MERLIN as well. JŠnos
Janos, what are you using as source? PC, Mac, Squeezebox, other? Which player? Foobar, Audirvana, other?
Sebastian
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
