USB to I2S 384Khz - DSD Converter USB to I2S 384Khz - DSD Converter - Page 171 - diyAudio
Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 23rd August 2013, 10:02 PM   #1701
Jackal29a is offline Jackal29a  Spain
Thanks for the pic!
BTW, firm 1.080 is available through the tool. It fixes pin 11 as XO selector, it didn't work in 1.079
Old 24th August 2013, 05:02 AM   #1702
miksi is offline miksi  Serbia
Originally Posted by Geosto View Post
Today i received mine and here you see what pins are used for the F0,F1,F2 and F3.
And the back.
Thank you Domenico for your nice product.
Best regards George
From the images posted it's obvious that F0 - F3 are pins 17-20 and pin 16 is labeled D64 and that should be latest rev. board. So, be very careful with Acko reclocker boards because it's not fully compatible with this rev. One should remove connections - header pins on these positions to avoid connecting them to ground.
Old 24th August 2013, 06:42 AM   #1703
amanero is offline amanero  Italy
hello, the lines are in sequence D64 (F0) F1 F2 F3
They are open collectors and you can ground them when not used.
Old 25th August 2013, 06:49 AM   #1704
We have schematic for old revision (which I have) but which IC pins were used for D64,F0-F3? Only F3 and F2 lines are clearly visible on the images.
Old 25th August 2013, 07:59 PM   #1705
acko is offline acko  Australia
Thank you Domenico. You have exceeded all expectations!
AckoDAC Project
Old 30th August 2013, 07:08 AM   #1706
skyfighter is offline skyfighter  Turkey
If I write my name to the list, can I catch the GB6? When can it be shipped?
Old 1st September 2013, 11:58 AM   #1707
Rookie is offline Rookie  Serbia
Rookie's Avatar
I recieved my board!
Is there a newer datasheet with pin descriptions?
What is D64 pin?
Old 3rd September 2013, 06:31 AM   #1708
asa00322 is offline asa00322  Taiwan
I recieved my board! today
thanks
Old 4th September 2013, 01:54 PM   #1709
Default Revision B1203K
http://www.amanero.com/USB_E.pdf
http://www.amanero.com/CPLD_E.pdf
http://www.amanero.com/drivers/combo384-D4.pdf
Schematics with F0,...
Thank you!
Domenico
Old 4th September 2013, 02:24 PM   #1710
deanoUK is offline deanoUK  United Kingdom
Default Data Sheet
Thanks Domenico.
This extract from the data sheet may stop people reading any further-
"The module works in Master Mode Only, it means that it doesn't accept an external clock in.
input."
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
