Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 11th July 2013, 06:52 AM   #1621
Jackal29a is offline Jackal29a  Spain
It makes sense.
Have you checked if pin 6 has no voltage when playing?
Old 11th July 2013, 12:52 PM   #1622
BackinBlack is offline BackinBlack  England
BackinBlack's Avatar
The firmware download has a Readme.pdf included. The file contains the instructions, but we don't read those, well real men don't??!! That process worked OK for me.
Reminds me of a label I found on the back cover of a model airplane power pack - "If this unit appears to malfunction or behave unexpectedly, then READ the MANUAL. OK, now do you need to remove the back? And, No, I never did remove the back!!
Old 11th July 2013, 02:39 PM   #1623
MisterRogers is offline MisterRogers  United States
Can you say Audio?
Ha! figures. Re: reading pin 6, no - not yet. We're in the middle of packing to move and my brief stop at the bench to flash the firmware was greeted by the icy daggers from my lovely wife :-) I hope to dive in this evening.
Old 11th July 2013, 06:23 PM   #1624
clsidxxl is offline clsidxxl  France
clsidxxl's Avatar
I think use this cable to connect my interface
2 partagé sur ZimageZ
it looks such as RG 316 Wire Invalid Request ,votre avis?
Old 13th July 2013, 03:23 AM   #1625
Can you say Audio?
Ok. The steps I detailed above successfully flashed the Amanero into slave mode. Full sync is partially working (confirmed that clock is being supplied to pin #6). I have more troubleshooting to do though. 96K plays slow - like clock select isn't selecting the proper clock, or maybe the divider circuit isn't working properly. Seems 24 & 88 work fine. Anyway, just thinking out loud. I have to park it until I return from a trip next weekend.
It'll be nice to get the bugs out; full sync with the crystek clocks sounded very, very nice.
Old 15th July 2013, 05:49 PM   #1626
gianmaria is offline gianmaria  Italy
Default New group buy
Dear All,
is there anybody interested in a new Group Buy of the card?
...or is there anybody who knows if are there any GBs open?
Thanks in advance,
GM
Old 15th July 2013, 06:47 PM   #1627
The GB sheet is at Post 34 -
https://docs.google.com/spreadsheet/...wYS1EcXc#gid=0
Old 16th July 2013, 06:27 AM   #1628
GeorgeBoles is offline GeorgeBoles  Australia
GeorgeBoles's Avatar
Good Afternoon All.
I am about to purchase the Twisted Pear Buffalo IIISE DAC. Probably playing out of a Mac Mini via USB or an old Windows computer USB.
Are the Amanero USB-I2S and the Buffalo IIISE compatible with very few difficulties? (As is usual, when I peruse a bulletin board such as this, usually most of the posts describe problems rather than joyful outcomes.)
I am happy to wire things up according to instructions, using a bit of logic and common sense along the way, and to flash some chips as required, but I have no skills in diagnosis of digital problems.
Should I expect this all to work more or less on the first attempt?
George.
My Website - borne out of frustration, but expanded for fun.
DIY HiFi, Combat Flight Sims & some stolen antiques
Old 16th July 2013, 08:29 AM   #1629
you can connect it without difficulties.
Read this thread or the hifiduino one, you'll find more info than you need.
Good luck!
Old 17th July 2013, 05:59 AM   #1630
DQ828 is offline DQ828  Australia
DQ828's Avatar
Originally Posted by GeorgeBoles View Post
Good Afternoon All.
George.
I connected my Amanero straight (4 wires) to the BIII-SE & it worked first time no issues
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright ©1999-2017 diyAudio
