Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 7th May 2013, 07:21 AM   #1501
Tazzz is offline Tazzz
Originally Posted by s3tup View Post
Not a brand new hardware revision, but a new cpld firmware which will turn the mclk into input - the preset is already in the configurator utility, we've gotta wait for more information from Amanero.
A Clock select is also needed is there a pin allocated for that too?
Old 7th May 2013, 08:27 AM   #1502
Jackal29a is offline Jackal29a  Spain
XO selection should be available using pins 1 and 11.
44.1K based pin1= On Pin 11= Off
48k based pin 11= On pin 1=Off
Old 9th May 2013, 03:25 PM   #1503
martinduchesne is offline martinduchesne  Canada
hooked up my amanero to a twisted pear opus dac. Setup dipswitches as specified. Hooked up everything like needed. No sound from output..
How do i know wich of Amanero or Opus is the problem ? How do i know if the amanero output i2s signal to my Opus ?
Old 11th May 2013, 03:20 PM   #1504
dracoV is offline dracoV  Thailand
2 boards received. Thank you.
Old 11th May 2013, 03:31 PM   #1505
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Measures if outputs DC with a DVM.
Old 11th May 2013, 05:44 PM   #1506
You mean to remap "cable plugged" (pin 1) and "Mute" (Pin 11) into two clock selects?
IMHO one CS is enough and I would prefer to keep the Mute functionality.
Old 11th May 2013, 08:14 PM   #1507
s3tup is offline s3tup
s3tup's Avatar
2nd this. Mute is handy. Heh, CablePlugged too
Yet, i could live without 'em as long as i have the MCLK slave thing.
The missing link between lead and gold in alchemist's world was BS and commerce.
Old 12th May 2013, 08:59 AM   #1508
Yep, that is what Amanero told me. That arrangement allows for a very simple external reclocking using the enable pin of the XOs.
I guess you can't have all but the Slave mode firmware is optional so anyone can decide if the benefits outwheights the inconeniences. Maybe using I2C commands in software mode DACs can compensate the loss of the mute pin? or perhaps even using an I2C port expander can be used for selecting external XOs (with the exception of 48K based DSD for which there are no separate events).
Old 13th May 2013, 02:13 PM   #1509
hktvro is offline hktvro  Hong Kong
Boards received.
Thank you.
Old 13th May 2013, 03:11 PM   #1510
YHPM
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
Copyright ©1999-2017 diyAudio
