Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 24th April 2013, 07:05 PM   #1471
gentlevoice is offline gentlevoice  Denmark
.... And then I have another couple of questions that I hope one of you can answer: Will it damage the combo384 - or make it not work - if the powersupply voltages for the combo384 are:
1. up to their rated value a bit later than the USB signal (e.g. ~1 second), or
2. on permanently even if there's no USB signal?
Insights appreciated ;-)
Jesper
... Found this in an earlier post (1174):
Amanero board must be fed after plug USB. The best way to obtain this is one relay driven by +5v of USB. This relay connect (USB plug) or disconnect (USB unplug) your external supply to Amanero board.
. So I guess this answers my question.
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 24th April 2013, 08:08 PM   #1472
grufti is offline grufti  United States
grufti's Avatar
Differences in wire length do not matter for the integrity of the I2S signal at the typical length involved in these circuits, totally completely not at all, trace impedance matters.
Old 24th April 2013, 08:42 PM   #1473
hktvro is offline hktvro  Hong Kong
Invoice received and paid! Thank you!!
Old 25th April 2013, 07:39 AM   #1474
@grufti:
Thanks for replying ... but so that I may relate to what you write relative to my own knowledge and experience (e.g. what I wrote) can I then ask you to write why it is so? I am familiar with the impedance considerations.
Best regards,
Jesper
Old 25th April 2013, 09:18 AM   #1475
grufti's Avatar
The wavelength of 50 MHz is 6 meters in vacuum [about 5.7 meters in copper traces]. 1 cm difference in length is a small fraction of that and most important of all constant. All current DACs that I'm aware of deal with that offset between signals without any impact on performance.
Old 26th April 2013, 01:19 AM   #1476
yslab is offline yslab  Japan
Dear Domenico,
Board received today.
Thank you.
Old 26th April 2013, 03:11 PM   #1477
@grufti:
Thanks again for replying ... I'll just ponder and see how it adds up with everything else ;-)
Greetings,
Jesper
Last edited by gentlevoice; 26th April 2013 at 03:27 PM. Reason: Inserted the wrong quote ...
Old 26th April 2013, 04:50 PM   #1478
BackinBlack is offline BackinBlack  England
BackinBlack's Avatar
Hi Domenico,
Many Thanks
Ian RJ
Old 28th April 2013, 04:20 PM   #1479
gbyleveldt is offline gbyleveldt  South Africa
gbyleveldt's Avatar
Added as gbyleveldt #413 for 4 boards.
PM Sent
The walls between art and engineering exist only in our minds - Theo Jansen
Old 30th April 2013, 02:04 PM   #1480
LuisMCP is offline LuisMCP  Spain
Audio fanatic
LuisMCP's Avatar
Default New functions added?
Hi Domenico,
I get the Combos yesterday.
I see four new labeled pins: F1, F2, F3 and D64
Have you a new datasheet?
Luis.
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
