Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 18th March 2013, 01:31 PM   #1361
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Originally Posted by Bunpei View Post
Hi, Merlin el mago,
I'm not familiar with foobar2000. Does the real time converter support DSD256, DSD512?
Bunpei
Originally Posted by Jackal29a View Post
Nope, it only does DSD64 and DSD128 but it is the only app I know that does this for free. It is based on Philip's ProTech Audio Format Converter.
Javier Bunpei knows HQPlayer?
Old 18th March 2013, 02:07 PM   #1362
Jackal29a is offline Jackal29a  Spain
Yes, he does
Old 18th March 2013, 02:22 PM   #1363
Yes, he does
yhemail
Old 18th March 2013, 07:28 PM   #1364
corneliup is offline corneliup  Romania
Board received today
Many thanks!
Corneliup
Old 19th March 2013, 04:39 PM   #1365
lucaslucas is offline lucaslucas  United Kingdom
Installed and working perfectly with buffalo dac from foobar and win7 driver. Provides a real(ism) improvement over the optical input I was previously using.
A great little device.
Many Thanks
Old 20th March 2013, 02:43 AM   #1366
henry97 is offline henry97  United States
Just received the card, thanks Amanero.
Old 20th March 2013, 06:50 AM   #1367
SCompRacer is offline SCompRacer  United States
I'd like to explain briefly a method to get DSD256, DSD512 files from your own existing sources.
Thank you for explanation!
Your PM box is full.
Old 21st March 2013, 12:03 AM   #1368
Bunpei is offline Bunpei  Japan
I keep my inbox deserted because I do not want to use it.
If any of you need to send a message to me, would you please use a usual internet e-mail;
bunpei <at> ta2 <dot> so-net <dot> ne <dot> jp
Old 21st March 2013, 12:09 AM   #1369
Default DSD input to AK4399 based DACs
Though the DSD source transport was not Combo384, I have tried a DSD play on an AK4399 Evaluation Board. It accepted DSD64 without any problem. However, not for DSD128 nor higher.
Old 21st March 2013, 01:14 AM   #1370
miksi is offline miksi  Serbia
Default DSD playing
I use quite standard combination of buffalo iii dac with Amanero and WaveIO USB receivers, Ivy III, placid HD supplies, Otto II, arduino controller ... The problem I have is when playing DSD, then at the Ivy III outputs appears DC, on the left channel -1.4V and right -0.7 V. With I2S (PCM) there is no problems. The display shows the correct sampling frequency. I've checked the DC voltages and everything is fine, although I do not have an oscilloscope to see what is really going on. Oh, yes, I have the DSD sound, but is somehow clicking and crackling...
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
