USB to I2S 384Khz - DSD Converter USB to I2S 384Khz - DSD Converter - Page 135 - diyAudio
Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 16th March 2013, 08:21 PM   #1341
themystical is offline themystical  United Kingdom
Originally Posted by dickiegeorge View Post
Yes, but I want other inputs than just Amanero. I have implemented a controller prior to getting this board and just trying to integrate it fully....
I use an Arduino to I2C control the registers in the ES9008 within my Buffalo24. The Amanero Board also connects to the same I2C network. The I2C network is at 3.3V as the Amanero Board is not theoretically 5V I2C tolerant. The Arduino acts as both a Master (in communicating with the ES9008) as well as a Slave in receiving information from the Amanero Board. Your pic controller could probably be a "Master" and a "Slave" at the same time but you would need to investigate this with whatever controller you are using.
I basically use the Frequency events (44k,96k etc) and the PCM/DSD events and indicate them on the LCD display as the ES9008 does not have the "Status" registers that the ES9018 has - there are only the first 15 registers of the ES9018 in the ES9008.
Ray - You probably don't need the I2C multiplexer - just configure your Arduino to be a slave as well as a master.
Old 16th March 2013, 09:30 PM   #1342
prawlins is offline prawlins  United Kingdom
Received my board today - many thanks!
Old 16th March 2013, 11:22 PM   #1343
dickiegeorge is offline dickiegeorge  United Kingdom
From my limited knowledge I2C is designed to operate with a single master on a bus and all the work I've done is based with this in mind. It may well be the case that Arduino can operate as both master & slave - I need to investigate further - but it will surely add interesting problems, for instance what happens when both masters want to send at the same time? Could get messy
When i first saw that the Amanero had I2C capabilities I assumed it would be as a slave device with registers that could be read to detect its status, similar to DAC chips. Hence my question asking about this earlier. I do however fully appreciate why Domenico has taken the master approach and can see the advantages for those looking for a simple integrated approach.
I look forward to seeing what Ray comes up with his Arduino. I really like the idea of being able to control the DAC volume (and other settings) via the usb interface - I had been thinking of doing something similar (but probably using ethernet and setting up a local web service to control the DAC).
Thanks for all the input - much food for thought.
Old 17th March 2013, 08:18 AM   #1344
Multiple masters on the I2C bus proven and working with an Arduino! In fact I have not even removed the original TPA "master" pic controller on the Buffalo24 Board - just delayed the the Arduino connecting to the I2C bus until after the original pic controller has been put into "sleep" mode by its original programme. Off course it all needs to be "engineered" to work.
I am also interested in Ray's method so looking forward to the details in due course.
Old 17th March 2013, 11:00 AM   #1345
Bunpei is offline Bunpei  Japan
Trying to understand what you are saying here Ray. Does this mean that in my Buffalo24 because I can use the software volume control with DSD input, the DAC is actually converting native DSD to PCM? i.e that is the way DSD works in this DAC chip by converting to PCM?
Originally Posted by RayCtech View Post
If you use (control) the volume by programming the DAC chip registers there are no extra conversion involved, but if you use the volume control in the player app then it most possibly must convert DSD to PCM and send PCM data to the DAC.
Hi, themystical,
I'd like to supply additional information based on my experiences.
A volume control on DSD (1 bit delta-sigma modulated) data always requires a multi-bit mathematical operation. When a volume control function is implemented somewhere in your system, the original DSD data is essentially converted into multi-bit data somewhere. Please remember the word "multi-bit data" which is not equivalent to PCM is used here.
1. in players ?
I just know HQPlayer & JRiver Media Center 18 cases.
In those players running under ASIO 2.1 DSD streaming mode, volume control function is unconditionally disabled for a DSD source because those players send native DSD streaming data to ASIO driver side.
2. in DAC ?
It is DAC architecture dependent.
As for ES9018, it employs 6 bit delta-sigma modulation and DSD data is volume controllable. I imagine that DSD data might be decimated into 6 bit delta-sigma data through its digital FIR filtering process. In the process, its volume control functionality must be implemented.
As for TI BB XXX179x DACs (for example, DSD1794A, PCM1795) of Advanced Segment architecture, input DSD data is only processed by a simple analog like FIR filtering through the Advanced Segment so as to get a final analog signal. No volume control function is provided for a DSD input on this architecture. FN1242A made by Niigata Seimitsu must be similar. Because of the simple internal mechanism, these DACs can be used even for playing DSD256 and DSD512 though it is not explicitly specified nor guaranteed in their datasheets. (In some worst cases, you may have noises on these DACs for the high sampling DSD data.)
Bunpei
Old 17th March 2013, 11:15 AM   #1346
That's good to know - thanks.
I need to dig out my Arduino again and have a play
Old 17th March 2013, 11:15 AM   #1347
How many sources of DSD256/DSD512 music are there?
When we think of sources originally recorded at those sampling rates and widely available, as far as I know;
DSD256: Only one from 1 bit Consortium web site
DSD512: None
(Therefore, in my own case and in the cases of the most of users in Japan those who have tried the high sampling rates they craft DSD256 and DSD512 sources by themselves. The technique will be shown later.)
As some professional level ADC devices support a DSD256 output, there must be more sources in the professional studio world.
Old 17th March 2013, 11:17 AM   #1348
Originally Posted by Bunpei View Post
1. in players ?
Foobar is the same - outputting DSD disables the volume control.
Old 17th March 2013, 11:23 AM   #1349
I'd be interested in seeing this (Audiogate perhaps?).
Old 17th March 2013, 11:44 AM   #1350
Hi, dickiegeorge,
I'd like to supply additional information for I2C control.
As "themystical" has already shown in his post, multiple masters are ok on a single I2C bus. I2C specification is designed to allow a multi-master configuration employing a arbitration mechanism.
http://www.nxp.com/documents/other/39340011.pdf
A possible cause of problems in a multi-master environment might be a problem of implementation of multi-master support on individual programs.
The following discussion might be interesting for you,
Arduino I2C Multi Master design - Arduino Forum
The device, Raymond showed, is to be used for multiple devices in a single application domain to have fixed identical duplicated addresses. For example, if you have four ES9018 DAC chips on one board, the use of the multiplexer/switching device must be effective. The application of the multiplexer device is nothing to with the case of multiple masters in a single I2C bus.
Bunpei
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
Copyright ©1999-2017 diyAudio
