Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 17th February 2013, 02:20 PM   #1231
neb001 is offline neb001  United States
Added my name to the list
Old 17th February 2013, 08:07 PM   #1232
supra is offline supra  Australia
Originally Posted by s3tup View Post
Yes, TDA1541 works with Amanero out of the box.
Connections are rather direct and intuitive -
WS = LRCLK = FS (Frame Sync)
BCLK = BITCLOCK
DATA = DATA
Don't forget to use a ground wire next to each signal wire - use ribbon with the following arrangement:
GSGSGSGSG
where S means signal and G means ground(GND).
Confirmed up to 96kHz material.
192/174kHz doesn't work as the Amanero hit TDA's limitation on BCLK frequency of 5.6MHz (BCLK=32Fs on TDA Vs BCLK=64Fs on Amanero)
Thank you, much appreciated.
Old 20th February 2013, 05:28 AM   #1233
smoothquark is offline smoothquark  United Kingdom
Is there a matching DAC planned? If so, time frame? I haven't received a pm or invoice yet for the group buy.
Old 20th February 2013, 06:42 AM   #1234
dickiegeorge is offline dickiegeorge  United Kingdom
Default Raspberry Pi ?
Has anybody tried the Amanero with a Rasberry Pi yet?
I'm debating getting a RP to try as it could make for a nice, compact media solution, but I've heard there has been problems getting USB audio to work well in the RP.
Old 20th February 2013, 11:48 AM   #1235
MrSlim is offline MrSlim  Canada
There are threads about the Rpi elsewhere on DIYaudio, and someone has had reasonable results with the audio widget interface, up to 24/96, with USB 2.0, as long as the devices on the USB bus are all USB 2.0 (I.e. no keyboard connected(which would be USB 1.0))
Old 20th February 2013, 01:05 PM   #1236
Thanks for that - I need to do some more digging.
Old 20th February 2013, 02:41 PM   #1237
palmito is offline palmito  United States
palmito's Avatar
The audio widget thread started intrespersing RPI stuff starting around this post:
http://www.diyaudio.com/forums/digit...ml#post3320020
There's also this dedicated thread:
http://www.diyaudio.com/forums/digit...gital-hub.html
I have not succeeded in playing completely glitchless music out of my RPI. Maybe I have a dud.
Old 20th February 2013, 07:50 PM   #1238
Have you tried strictly headless? That seems to help quite a lot..
Old 21st February 2013, 08:04 PM   #1239
Hdale85 is offline Hdale85  United States
Does anyone have a rooted android device with an OTG cable? I'd be interested to know if this will work with that? I'm considering one of these for a car audio interface from an Android based device (Possibly Arndale board, would be Arndale>Amanero>Buffalo III SE>MiniDSP 2x8).
Also is there a group buy currently going on?
Old 22nd February 2013, 12:47 AM   #1240
PET240 is offline PET240  Australia
yes there is a GB, best jump on spreadsheet soon.....have a look through the last 10 pages or so for the sheet.....
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 02:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 11:41 AM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 04:09 PM
