Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
USB to I2S 384Khz - DSD Converter
Old 29th December 2012, 10:01 PM   #1091
glt is offline glt  United States
Easier than that:
Store value of register in a variable, set or clear bits of interest, done. Optionally save value in eeprom.
www.hifiduino.wordpress.com
Old 30th December 2012, 12:13 PM   #1092
RayCtech is offline RayCtech
Originally Posted by glt View Post
Easier than that:
I do not think you got the "message"
The problem are however that the bits of interest are "set or cleared" from different parts of the code...
When a register have multiple functions the code may by "accident" change some unintended bits... and "forget" to change the displayed info accordingly etc. etc..
I have gone a bit further as I split each function of a register (as shown in my example) in separate variables and when changing one function only that functions variable are tinkered with. Thus when writing to the register all the variables a register may contain are summed (as shown in my example) - this allows the correct use of absolutely all combinations of a register failsafe.
I also (of course) both saves and recalls all variable to / from EEPROM.
Each configured input (I2S/PCM, I2S/DSD and SPDIF (multiple of all of them) also have separate sets of variables stored / recalled to allow the DAC optimized register settings pr. input. When register settings for one input have been tweaked optimally only a push of a button on the remote are needed to save all associated register values for that input to EEPROM. Thus each input can have different quantizer, DPLL, filter etc. settings and when the input selection are changed the DAC chip are reprogrammed optimally for each separate input device.
Old 2nd January 2013, 07:44 AM   #1093
thomaspf is offline thomaspf  United States
Default 32 Bit playback possible under Jriver?
I have finally had the time to play a bit with the Amanero adapter. I updated to the latest firmware and driver version 1.56.
I can select a 32 bit output format for foobar but I get an error when I do that for Jriver. I will check again tomorrow when I have access to that system but I seem to remembers that this works fine in Jriver with the Musiland adapter.
Cheers
Thomas
Old 2nd January 2013, 07:56 AM   #1094
amanero is offline amanero  Italy
Hi Thomas, use MediaCenter 18 output 32 bit in integer mode not in floating point
Domenico
Old 2nd January 2013, 07:09 PM   #1095
grmgrmgrm is offline grmgrmgrm  Serbia
Hello everyone!
I ve had problem with recognizing device under Mac OS and win 7, so i upgraded firmware and installed newest driver - 1.0.56 - for win. After resolving that issue, i ve tried to connect amanero with Ak 4396, on this way:
amanero - ak dac
pin3 data - data
pin4 bclk - sclk
pin5 fsclk - lrck
pin8 gnd - gnd
No sound at all, Mac or Win7 - just noise on mac, silence on win. Is there anything wrong with setup? (with teralink USB-I2S everything works as earlier..)
Amanero is revD - if that is some important for helping me
Thanks for helping in advance!
Old 2nd January 2013, 07:46 PM   #1096
ultrafi is offline ultrafi  United States
In OS X, did you go into Audio Midi and set it to something less than 384k?
Old 2nd January 2013, 07:55 PM   #1097
yes
Old 2nd January 2013, 08:14 PM   #1098
MCLK?
Old 2nd January 2013, 08:17 PM   #1099
so, i will try with it.. i thought there is not need for MCLK - will inform u soon - thanks
Old 2nd January 2013, 08:52 PM   #1100
yeeesss - now it works - tried on mac - perfectly..he he he. . just to hide out how to play dsd stuff on mac and i can fly and just to find out why kubuntu doesnt get me to use amanero as option for audio playback - i can see it in audio hardware, but not in the list where i can choose what device i want to use for playing music - then, i come to italia and buy huge booootle of finest beer to me domenico
USB to I2S 384Khz - DSD ConverterHide this!Advertise here!
HLLY USB SPDIF/ I2S CONVERTER kp93300 Digital Source 12 29th January 2012 03:55 PM
exaU2I - 32bit/384kHz Multi-Channel Asynchronous USB to I2S Interface exa065 exaDevices 0 11th November 2011 12:41 PM
$40 USB to I2S converter sharpi31 Digital Line Level 7 12th July 2009 05:09 PM
