Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
SRPP buffer PCB board for sell-10pcs
Old 2nd June 2012, 03:22 PM   #21
puremilk is offline puremilk  Singapore
Default No problems,you are welcome!
Originally Posted by merlin el mago View Post
Hello Alfred,
Thanks in advance
Felipe
Old 2nd June 2012, 03:48 PM   #22
Default Thankyou to trouble you!regards
Originally Posted by SY View Post
Since this is clearly a commercial venture, I am moving the thread to Vendors.
Old 3rd June 2012, 02:24 AM   #23
sasha70 is offline sasha70  United Kingdom
Payment and PM sent.
Best regards.
Sasha.
Old 3rd June 2012, 03:48 AM   #24
Default Got your payment and pm sent.Thanks and Regards
Best regards.
Sasha.
Old 13th June 2012, 10:17 PM   #25
merlin el mago is offline merlin el mago
merlin el mago's Avatar
Arrived today safely and well packed the pcb.
Old 14th June 2012, 08:05 AM   #26
Default SRPPPCB
so the packet arrived safely,do let me know if you have any installation problems.
also i assumed you have recieved the installation manual in pdf form to your email.
Old 14th June 2012, 10:04 AM   #27
Yes I received the manual pdf, if I have installation problems I will let you know.
Thanks for all.
Old 15th June 2012, 05:18 PM   #28
Thank you, I have received PCB today and pdf earlier.
Good quality board.
Question about heater voltage:
According PCB design: it is a voltage regulator for heaters 2x +6v, can I use resistor instead to make it 6,3v as recommended?
Best regards.
Sasha.
Old 16th June 2012, 03:30 PM   #29
Good quality board.
Best regards.
Sasha.
I try to answer your questions if i got what you meant.
regulator 2x 6v DC uses for two channels(L&R)tube's filaments if you choose the 6.3V filament tube type(like ECC88,ECC85,6FQ7,6CG7,6N1,6N11 etc)but if you want to series the 2x6V DC into 12VDC and drop down the voltage to 6.3V to supply for L+R channel tubes filament,i will suggest not to do so for the reasons:
1)it does not seems much will affect if filament run in 6V or 6.3VDC,cos DC gives more stable voltage after regulation.0.3V is almost can be nelected in DC.
2)besides if you want to run them in 6.3VDC by dropping voltage from 12VDC
you need to calculate the voltage dropper resistor value for the particular tube's filament If=?ma,in order to get 6.3V DC out correctly which i think it is not very advisable to do so.
Let me know if i had answered your question promptly.
Old 17th June 2012, 11:39 PM   #30
Hi,thank you for answer.
I'm planning to use Russian 6N6P tubes with transformer secondary's 2x6,5v for heaters.
resistor will easy to calculate with heater current on this tubes 750mA +/- 70mA.
According my calculation 0.26 Ohm resistor will do the job.
Best regards.
SRPP buffer PCB board for sell-10pcsHide this!Advertise here!
6N16 12x preamp srpp/cathode follower with printed circuit board design. Koifarm Tubes / Valves 65 30th September 2015 10:10 PM
SRPP with buffer - 1MOhm impedance? Bertel Tubes / Valves 30 25th November 2009 10:35 AM
12AU7 SRPP buffer suggestions Salas Tubes / Valves 25 19th April 2007 09:34 PM
MARK LEVINSON 38 board for sell !!!!!!! trigon Swap Meet 3 7th September 2004 11:12 PM
