Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Combined Onaudio thread. (23 threads)
Old 7th September 2012, 07:08 PM   #701
OnAudio is offline OnAudio
OnAudio's Avatar
Default OPB PCB
If interested add your name to this list.
The amplifier can be found here
HAL OPB amplifier
Old 7th September 2012, 07:15 PM   #702
OnAudio's Avatar
Default 2DIFFEF PCB
http://www.diyaudio.com/forums/solid...amplifier.html
Old 7th September 2012, 10:53 PM   #703
OnAudio's Avatar
These could also be used
MJH6284G ON Semiconductor | MJH6284GOS-ND | DigiKey
Old 18th September 2012, 02:29 PM   #704
undefinedza is offline undefinedza  Europe
Hi OnAudio,
What exactly is the procedure here?
I'd like to build this amplifier.
Chris
Old 18th September 2012, 05:34 PM   #705
OnAudio's Avatar
Originally Posted by undefinedza View Post
Hi OnAudio,
Chris
Your Free to start a group buy. Drowranger was preparing a PCB. If his isnt ready will prepare one .
onaudio.herokuapp.com
Old 20th September 2012, 10:46 PM   #706
gaborbela is offline gaborbela  Canada
Default PC board order info
Hello
I'm interested on one pair SYMEF amplifier ad also on these "PC boards attached" one pair...
How I can order or participate in the "group buy"
Greetings Gabor
Old 25th October 2012, 09:33 AM   #707
Francois G is offline Francois G  United States
Default How to attach the output transistors
[/URL]
My SYMEF type 2 PCBs arrived and look great. Thanks HAL. They seem the same as this draft, at least regarding the orientaion of the output transistors.
I am puzzled however with the orientation of the output transistors. How do I attach them to the heatsink and get the leads in the right PCB orientation as shown.
I'll appreciate an explanation; picture would be even better.
Thanks,
Francois
Old 25th October 2012, 03:32 PM   #708
evette is offline evette  Canada
Send a message via Yahoo to evette
Simple Mount the outputs under the board and gently bend the leads. Regards Evette
Old 25th October 2012, 04:34 PM   #709
Evette,
Thanks for your reply.
The problem is that if the output transistors are mounted to a heatsink (with the metal tabs on the heatsink) then the leads have to be "switched" to match the PCB orientation of the leads. Am I misunderstanding something?
Thanks.
Francois
Old 25th October 2012, 04:46 PM   #710
Mr. Sir Francois if you take q5 and lay it flat on your hs towards the fuse holder now line up your pcb over the top of it and you,ll see they line up ( lead wise) perfectly. Regards Evette
Combined Onaudio thread. (23 threads)Hide this!Advertise here!
