Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Intelligent Curve Tracer 3.0 release
Old 20th February 2012, 12:44 AM   #11
locky_z is offline locky_z  China
Out Box LED is Overcurrent protection indicator,It always not bright.
The Power LED indicator inside Box.
You can use some wire connect slot X Y Z,and power on, and you will hear 8~9 relay voice,this mean the MCU is OK.and the communication rate will auto set to 28800bps.
And then you run software, press 'Autodetec'
the .pre extension file is save the 'Measurement conditions' file,you can use notepad to open.
Old 20th February 2012, 12:49 AM   #12
ljm_ljm is offline ljm_ljm  China
Very good.I have many acquaintances in the use of your design tester.
Old 20th February 2012, 05:39 AM   #13
wintermute is online now wintermute  Australia
just another
wintermute's Avatar
Thread moved to vendors bazaar due to commercial interests.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 21st February 2012, 03:23 PM   #14
pchw is offline pchw  United States
Taoboa said 此宝贝已下架, do you have another link that I can use to buy?
- Fred -
Old 21st February 2012, 03:29 PM   #15
Lazybutt had already bought them all from taobao.
Old 21st February 2012, 03:49 PM   #16
Thanks, I thought I could ask my friend to buy a complete unit for me instead of waiting for the GB :-)
- Fred -
Old 21st February 2012, 06:51 PM   #17
mos57 is offline mos57  Italy
mos57's Avatar
Locky, i am not able to view the output curves of my 2sa970 transistor under test, but i view only singles point as this image
Old 22nd February 2012, 01:02 AM   #18
1.You use RB=500ohm ? It could make Ib too large,and lead to Vce too small,and measure process will termination.
Intelligent Curve Tracer 3.0 release-11-png
If you understand this measurement schematic, you will understand that the choice of the RB the RC and Vb range
Generally small single transistor measure is using RB=1360K or RB=91K and RC=1K.
another you check DTU pin.
Old 22nd February 2012, 02:27 AM   #19
bear is offline bear
expert in tautology
bear's Avatar
Will the software permit the acquisition and then later comparison of a number of curves, each of a different device under test?
What would happen if a user was to add an external DC amplifier )x10 ?) to increase the range of the collector voltage and then scale the measurement resistor to suit? (Vc)
Do you have over voltage protection on the measurement ("input") terminals so that things will not burn out in the event of excess voltage being present?
_-_-bear
_-_-bear
http://www.bearlabs.com -- Btw, I don't actually know anything, FYI -- every once in a while I say something that makes sense... ]
Old 22nd February 2012, 03:58 AM   #20
Because the resistor in different device maybe not match,so the result is different device may different,but the different is tiny.
Example measure hfe, in a device is hfe=100,but in another device maybe hfe=101.5, Because their The divider resistor and current sampling resistor may be not exactly the same.
The intelligent Curve Tracer not suitable for high voltage measure, and hard to increase range.
There are no over voltage protection,because the device not know what DTU is measuring,
It just follow your setting measurement conditions and the output voltage(max is 36V)
It had only the hardware of overcurrent protection.It only protect the Curve Tracer,can't protect the DTU.
Intelligent Curve Tracer 3.0 releaseHide this!Advertise here!
Curve Tracer Stefanoo Equipment & Tools 97 8th September 2017 02:01 PM
curve tracer barclaycon Equipment & Tools 7 6th March 2017 01:18 PM
curve tracer? maxpou Solid State 4 24th October 2009 05:29 PM
intelligent semiconductor characteristic curve instrument locky_z Parts 14 6th November 2008 11:07 PM
