Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
KT88 SE Basic or Master Kit
Old 14th February 2012, 12:03 PM   #71
iNSuL is offline iNSuL  United States
I felt the same way waiting six weeks for my transformers to be made.
Old 14th February 2012, 01:06 PM   #72
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
What manufacturer makes the custom transformers?
Best regards,
Regi
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 14th February 2012, 02:22 PM   #73
TerryO is offline TerryO  United States
TerryO's Avatar
Originally Posted by regiregi22 View Post
Oh god, waiting for the kit to come is going to kill my nerves. Repeat: Only 3 weeks, only 3 weeks....
Thank you for the link!
Regi,
Based on Dave R's results, it's well worth the wait. A very nice sounding amp!
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 14th February 2012, 03:06 PM   #74
Dave R is offline Dave R  United States
Dave R's Avatar
Best Regards,
TerryO
I agree - you will be glad when it's done.
I've run 6550 tubes for several weeks, and couldn't be happier with the performance. Out of curiosity, I thought I'd try some EL34's. I've only used them for a few days, and haven't made any real one-on-one comparisons. However, it seems that vocals are somewhat improved (if that's possible!) with the EL34's.
Dave
- Dave R
the 200% Norske
Old 14th February 2012, 08:59 PM   #75
scott17 is offline scott17
Best regards,
Regi
My sincere thanks to everyone for the great comments. I really appreciate it.
The transformers were custom manufactured for me by Heyboer. If you will notice the specs, special attention has been given to the output transformer with it's 58 Henry primary.
FYI: I'm still planning on shipping your kit tomorrow. I'll send a PM with details.
Thanks,
Scott
Old 15th February 2012, 04:22 PM   #76
regiregi22's Avatar
I would like to know, if it is possible, the size specs of the enclosure. While the kit is coming, I want to prepare the outer protective layer.
It is my first tube amp; but as far as I am concerned, I am pretty sure that I will not leave a HOT light bulb charged at those god-only-knows potential difference waiting for any clumsy person (read, me) to beat them. That's considering I am pretty careful person. Think about the persons hanging around my house and not being tech-concerned. The only thing that may prevent them to beat the valves could be hanging a warning post, a big one, as big as physically preventing them to beat the valves
Sooooo.... I am thinking in placing some kind of mesh around the amplifier, as a cover. Being not familiar with the tipical approach to this problem in the valve world, I think that one of the most cost effective solutions could be to use a bird's cage of the same size and screwing in to the chassis. That's why I would like to know chassis measures.
What other ideas are commonly used to avoid physical contact with the HV components?
That's another question going around my head: being valves a so dangerous area with those so high voltages, I see no one concerned about exposing transformers and valves in a so explicit way. Some may even call it a pornographic way
Coming from the low voltage SS world, I would be called crazy if I even dare to expose to the outside a MINIMAL spot of a transistor, resistor, capacitor.... everything goes covered and outside the (pre-assumed) unconscious user's physical access.
Making that long story short, I am thinking in using that, of an appropiate size:
Old 15th February 2012, 04:24 PM   #77
regiregi22's Avatar
And through the way, you get a free handle to comfortably carry your amplifier anywhere you want
Old 15th February 2012, 04:34 PM   #78
regiregi22's Avatar
It would be great if i was able to match one of those covers (or other mfg.) to the provided chassis with the kit:
Hammond Mfg. - Perforated Chassis Covers (1451 Series)
Old 15th February 2012, 05:07 PM   #79
regiregi22's Avatar
Can someone please measure the total height from chassis to the top of the tallest valve? My estimation is that, if chassis is 3" tall, the distance from chassis to the top of the tallest valve should be around 4". An estimation made only by looking at the assembly pictures.
May someone put a rule for a second and give me a hand?
Old 15th February 2012, 05:15 PM   #80
regiregi22's Avatar
Oh yeah! I found something that should fit as a d*ck in the *** (spanish's expression), perfect match. It is P/N 1451-30, a mesh that measures 17"x10"x5.2". Footprint of the supplied enclosure is 17"x10", and Hammond is the manufacturer too, so it should match perfect!
Bad news are the footnotes:
*NOTE: These chassis covers are NOT compatible with any of our wood sided chassis.
I think I can always remove the side panels, their only end are aesthetics....
KT88 SE Basic or Master KitHide this!Advertise here!
KT88 SE Complete Kit scott17 Tubes / Valves 289 4th March 2013 08:09 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 02:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 12:26 PM
My KT88 SE project JesseG Tubes / Valves 8 20th April 2008 04:26 AM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 08:19 AM
Copyright ©1999-2017 diyAudio
