Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
KT88 SE Basic or Master Kit
Old 28th February 2012, 02:18 PM   #111
regiregi22 is offline regiregi22  Europe
regiregi22's Avatar
I am interested too in the LED bias, will follow closely.
diyAudio, doing it as big as you can, JUST BECAUSE WE CAN!
Old 28th February 2012, 05:28 PM   #112
mcgreg66 is offline mcgreg66  Germany
Default LED Bias for beginners
Hi KT88 SE community,
I'm running this amp now for about a year.....
....and I just opened it to try some other components.
Can somebody explain to me exactly what to solder where for LED bias....I build this amp with Scotts excellent manual ...but I feel still like bloody beginner when I hear you talking about circuits aso
Gregor
Old 28th February 2012, 09:15 PM   #113
regiregi22's Avatar
I have read on the forum that it is possible to switch between triode, ultralinear and pentode mode. Is it possible to implement pentode mode on this design?
If your transformer has ultralinear taps you can use a 3 way switch to go from triode to UL to pentode mode. I put a switch like this in the guitar amp that ate the previously mentioned KT88's. 38 Watts in pentode, 30 Watts in UL and 18 watts in triode mode with about 400 volts B+.
Old 1st March 2012, 06:07 AM   #114
iNSuL is offline iNSuL  United States
Its been a year since I first built the kit so I decided to do a rebuild with some tweaks. Heres some pics of the new version. Tweaks: led bias on driver, cap changes to PIO, and a few resistor changes. Still loving every note that sings from this amp.
Old 1st March 2012, 10:16 AM   #115
debk is offline debk  United States
debk's Avatar
I added LED bias for the 6N1P. I used a pair of HLMP 1302 red leds (Digikey part number 1080-1042-ND) for each cathode. This led has a 2v drop so a pair of them will give about the same bias point the original resistor did.
I bought 10 of the leds and measured the voltage drop across each one and picked the four that were the closest matched. This was probably not necessary, they were all within 0.03v
The led bias made a very noticeable improvement in detail. The music sounded clearer and more accurate. It still very much had the tube warmth, but now with more clarity.
I think it is well worth the upgrade. It is easy to do, and does not cost much (leds $0.46 a piece or $0.33 each if you buy 10).
I think this made enough of a difference that if I were to build this amp again, I would use led bias to start with.
Deb
Old 1st March 2012, 11:53 AM   #116
regiregi22's Avatar
Hello Deb,
Can you post a simple schematic of how to connect the LED? Cathode side to ground? Should the bypass capacitor stay in place?
Thanks!
Old 1st March 2012, 11:59 AM   #117
debk's Avatar
It is very simple. Connect two leds in series. then connect the string to the tube with the cathode to ground. Remove both the resistor and bypass capacitor
Debra
Old 1st March 2012, 01:23 PM   #118
regiregi22's Avatar
Easy peasy!
Old 6th March 2012, 10:58 PM   #119
scott17 is offline scott17
Looks great! Are those giant caps in place of the 30uF plate filters?
Scott
Old 6th March 2012, 11:39 PM   #120
Thanks. They're the driver b+ bypass cap. The 10uF
KT88 SE Basic or Master KitHide this!Advertise here!
KT88 SE Complete Kit scott17 Tubes / Valves 289 4th March 2013 09:09 PM
AnalogMetric 6L6GC SE amp kit...thoughts about this kit? jmillerdoc Tubes / Valves 2 16th November 2009 03:51 PM
Kt88 Se overdrajv Tubes / Valves 0 16th December 2008 01:26 PM
My KT88 SE project JesseG Tubes / Valves 8 20th April 2008 05:26 AM
Kt88 Se hacknet Tubes / Valves 9 10th September 2004 09:19 AM
