IRS2092   (IRAUDAMP7S)  + IRFI4019 IRS2092 (IRAUDAMP7S) + IRFI4019 - Page 14 - diyAudio
Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Old 7th December 2011, 01:09 PM   #131
ljm_ljm is offline ljm_ljm  China
Originally Posted by MrSlim View Post
The over/under voltage protection I'm talking about in the International Rectifier 2092 Reference design is for the power supply voltages, not the input voltage..
No power supply voltage forced close protection function.
But the power supply voltage and IRAUDMP7S principle is the same.
The power supply voltage not more than recommended. May be damaged.
Don't lower than the value of the request, will work is not stable.
Old 7th December 2011, 01:12 PM   #132
L15D Power Supply (+ -50V)
Old 7th December 2011, 02:26 PM   #133
MrSlim is offline MrSlim  Canada
Can you provide an exact schematic of your design please? I know you based your design on the Reference Design, the differences can be confusing. If users are attempting to replace the resistors to us a lower voltage supply, it is not straightforward to identify which are the correct components to replace.
Old 8th December 2011, 07:51 PM   #134
exipnos is offline exipnos
Hi all,
I'm building a 7.2 active speaker system that will require about 20 channels of amplification. They will all be line arrays with some being 2 way and some 3 way. For the amplification, I am interested in purchasing 10 kits (20 modules) but wonder what else I need to consider. I would like to drive my speakers at 4ohm.
1. Could I use those boards and combine them into this type of multi-channel amp?
2. What will be the cheapest way for me to combine suitable power supply in order to power all channels. I rather not have one power supply for each two modules but maybe that is needed?
3. Would the above work or do I need to consider something else?
As you can hear I'm a novice to this but would love to build something myself.
Any advice is appreciated.
Exipnos
Old 9th December 2011, 02:58 AM   #135
Originally Posted by exipnos View Post
Hi all,
Sure, it's been done before.. I think these are great "modules" for multi-channel systems, since they are very small, for the power they are capable of.
Probably something like a SMPS supply from Connexelectronic. Cristi has a number of Power supplies with different ratings, 300 - 1000W, so you could run up to 4 channels per 1000W supply.
No, probably just casing, and layout, and if you want an all in one chassis, or split them up some way or the other..
Exipnos
Old 9th December 2011, 04:02 AM   #136
And the reference design is The same.
The reference.
Old 14th December 2011, 07:36 AM   #137
Frosteh is offline Frosteh  United States
Frosteh's Avatar
Default L15D or L15D X2?
What is the difference between these? How does the sound compare between one stereo board and two mono boards?
IRS2092 IRAUDAMP7S high end class D stereo Amplifier | eBay
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Old 14th December 2011, 05:21 PM   #138
noah katz is offline noah katz  United States
Or more channels, depending on power requirement and where the amps are located.
Something to keep in mind is that the heat sink fins of the stereo board be vertical, unless you use a fan, requiring a much taller case than the mono boards.
If that's OK, then you can fit more amp channels in a given volume.
Noah
Old 14th December 2011, 06:08 PM   #139
I'm interested in purchasing the L15D or L20D from one of these sellers but wanted to contact along1986090 before hand but could not find any contact info. ljm_ljm or anybody else have their details?
Old 14th December 2011, 06:13 PM   #140
Frosteh's Avatar
Does anyone know how tall this heatsink is (the stereo board)? I didn't factor that in. I have a 4" tall case.
IRS2092   (IRAUDAMP7S)  + IRFI4019Hide this!Advertise here!
Irs2092 luka Class D 50 15th July 2012 01:48 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
Irs2092 gxhcdba Class D 11 14th December 2009 10:54 AM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Copyright 1999-2017 diyAudio
