Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
IRS2092   (IRAUDAMP7S)  + IRFI4019
Old 29th October 2011, 05:54 AM   #111
noah katz is offline noah katz  United States
Ah, so it is, thanks.
Two out of three ain't bad; what's the height?
Is there a minimum space between adjacent boards and the amp modules and the PS?
Trying to figure out what size case is needed.
Noah
Old 29th October 2011, 09:49 AM   #112
Cyan is offline Cyan  Italy
I'm interested too, there are 2 cases found on ebay for power amp. One is large about 185mm, and it is large enough, but too large for the space I have. I can only use the 165mm one, and dunno if that is big enough.
Old 29th October 2011, 02:28 PM   #113
ljm_ljm is offline ljm_ljm  China
ljm_ljm,
With the heat sink vertical on the board it doesn't look like convective airflow over the fins will be very good, since the board underneath blocks it.
Do you know what is the maximum average power that a module can dissipate when in a closed box?
And how much if the box has ventilation holes above the heat sink?
Also , what are the dimensions of the board? I searched but didn't find them, and the ebay vendors don't give them either.
I send connection diagram in front have a mark on size.
The radiator height about 40 MM. Plus installation about 5 MM copper column。
L15D can use 30 MM height of the radiator. If be necessary, can indicate
Old 29th October 2011, 08:16 PM   #114
Thanks!
Cyan,
I've been searching for cases too, here are some other sources:
Audio Catalog
thlaudio web site pages
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
Hi-Fi 2000 contenitori per l'elettronica, case modding HTPC, Galaxy, rack, DIYaudio, computer cases, front panel express, knobs,milled Handles, milled fronts, hi-end,
modushop.biz
Par-Metal
Noah
Old 29th October 2011, 10:50 PM   #115
Nice thank you
Old 31st October 2011, 02:23 AM   #116
General protector
This and all of the other speaker protector boards on ebay say that they require AC.
I expect they work with DC also, but is there any issue with doing that?
The SMPS I will use has only 12 VDC auxiliary voltage.
Noah
Old 2nd November 2011, 03:07 PM   #117
No problem, but need to make some changes.
Will the DC12V + and-in the direct connection LM7812 can work OUT GND.
Old 2nd November 2011, 10:16 PM   #118
Sorry, I don't understand.
But if it helps, the PS has both + and - 12V outputs.
Noah
Old 3rd November 2011, 02:08 AM   #119
MrSlim is offline MrSlim  Canada
If you are talking about this one: http://www.ebay.com/itm/110620807058...84.m1438.l2649, you could remove the 7812 regulator, and run the +12 directly in to the printed circuit hole where it's output pin was. and the ground from the power supply would go on the regular ground point.. It would probably be a good idea to get a schematic for it as well. If you had the schematic, you could pull out the first component after the ac input connector so that the rest of the circuit was out of the way, and use AC12 as the input point (to keep it clean, and then run a wire from there to the (former) output of the 7812..
Old 3rd November 2011, 02:12 AM   #120
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Be careful what you do with the 12 volts to the 2092. It can be a bit touchy about decoupling close to the regulator and close to the 2092.
I didnt decouple mine well enough and I started getting clicking through the audio.
Turned out to be glitches on the VCC 12 volt rail.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
IRS2092   (IRAUDAMP7S)  + IRFI4019Hide this!Advertise here!
Irs2092 luka Class D 50 15th July 2012 01:48 PM
IRS2092 AMP help yaronshani Class D 3 29th January 2010 02:29 PM
Irs2092 gxhcdba Class D 11 14th December 2009 10:54 AM
IRS2092 help! yudi02 Class D 2 11th October 2009 03:30 AM
Copyright ©1999-2017 diyAudio
