Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Warpspeed -An Optocoupler Volume Control
Old 13th September 2011, 01:51 AM   #151
Blues is offline Blues  United States
Blues's Avatar
No, you can use whichever is most convenient...as long as the circuit is wired correctly and safely, all will be okay. Since the circuit runs in low current it does not require a humongous SLA battery. The design is quite robust, had been tested...but as always with electronics -accidents, random part failures, etc. are always part of the equation.
Life simplified! Leap into the Warpspeed wormhole... http://www.6moons.com/audioreviews/warpspeed/1.html
Old 19th September 2011, 03:29 AM   #152
Blues's Avatar
Default When you get to a fork in the wormhole, take it!
The Warpspeed CE family is now 3...the engine options are V4, V8, and V12(under evaluation):
V4 -single input Unbalanced only with dual pairs of paralleled outputs
V8 -switchable Unbalanced (in/out) or Balanced (in/out); dual pairs of paralleled Unbalanced outputs
V12 -Unbalanced with dual pairs of outputs with separate control for high and mid/low and master volume control. Passive bi-amping taking advantage of the loudspeaker designer's optimized crossover/driver combo. Two different amps (design/gain) for high and mid/low is now possible.
The inside of the V12 is pictured...
Old 23rd September 2011, 03:14 AM   #153
Blues's Avatar
Ahem...
Faster-than-light neutrinos? Astounding! - Technology & science - Science - msnbc.com
Old 9th October 2011, 03:01 PM   #154
DIYspaceW is offline DIYspaceW  Slovenia
Nice work...My warpspeed 10+ has now around 50 hours of listening and its the best manual volume control ever used so far....more to come....
Old 9th October 2011, 07:15 PM   #155
Blues's Avatar
Thanks Marko...but your suspense is killing me!
Old 18th October 2011, 07:52 PM   #156
Blues's Avatar
Some updates and reviews from users are here... Warpspeed Optocoupler
A thread over at the Hawthorne Audio forum has also been posted... http://www.hawthorneaudio.com/forums...php?f=8&t=4132
Old 18th October 2011, 10:51 PM   #157
Blues's Avatar
Default Battery Powered DeLorean! -sorry no flux caps here
An electric DeLorean in the works for 2013... Exhaust Notes - A Blog from MSN Autos - MSN Autos
Old 3rd November 2011, 06:52 AM   #158
Blues's Avatar
Default UAV
For those who have been rattling my cage...work is on to develop the RC option.
Like I've been posting before, it's quite a pricey proposition because I do not want to compromise on the motorized high precision potentiometer. This is the only way I want to go to keep the precision, accuracy, repeatability, and the step resolution to deliver controlled power to the optocouplers. With it I am able to optimize an optocoupler's full response curve from totally OFF to fully ON, which gives the Warpspeed the gradual increase/decrease of volume level that we have.
Expected availability is Feb 2012...thank you all!
Old 5th November 2011, 08:01 PM   #159
Blues's Avatar
Btw, DIYspaceW kept his word and sent the following by email...
"By the way the warp 10 is so great that I forgot to make reviews, that has never happened. Its the most transparent solution so far. I have also changed the output stage of the DAC, I use a 6s3p-ev tube and the output impedance is smaller, now around 1600-1800ohms.
It is difficult to make any review right now because the time I bought your warpspeed, I also got new output transformers. But it has become a real synergy between all my components now. On first note when I turned the system on I noticed the relaxation and clearness of the sound. I would say the classic R pots deform the harmonic structure of sound so much that the fine fragments get lost in space. This isn't the case with optocouplers. I noticed so much more information in music but not in analytical way, just enjoying the magic of music. The violin is violin with all the harmonics, a piano a piano...instruments are telling you their own stories...So for now I am impressed with my system and warpspeed has become a general important factor."
Thanks Marko!
Old 14th November 2011, 01:51 AM   #160
Blues's Avatar
Default The spawn...
V4 - 1-Input/2-Output(paralleled) stereo Unbalanced only
V4x2 - 2-Input/2-Output(paralleled) stereo Unbalanced only
V4x3 - 3-Input/2-Output(paralleled) stereo Unbalanced only; future product
V8 - switchable Unbalanced (1-In/2-Out paralleled) or Balanced (1-In/1-Out) stereo; No Unbal/Bal conversion
V8.1 - 1-In/1-Out Balanced only stereo with single level control
V8.2 - 1-In/1-Out Balanced only stereo with dual L/R level control
V12 - 1-In/2-Out Unbalanced only with separate controls for high, mid/low bi-amping, and a master volume control; fully tested
V16 - 1-In/3-Out Unbalanced only with separate controls for high, mid, low tri-amping, and a master volume control; future product
Updates and pic of the V4x2 here... Warpspeed Optocoupler
Warpspeed -An Optocoupler Volume ControlHide this!Advertise here!
Volume control on DVD player remote. Lose resolution at low volume? Circlotron Digital Source 2 10th June 2011 08:20 PM
CDM-4/19 running at warpspeed Pharao.Pharao Digital Source 13 5th May 2008 01:43 PM
i need preamp schematics w/o tone control or volume control hernanstafe Parts 7 30th January 2008 04:12 AM
The remote control paratactic volume control audio-gd Solid State 33 8th June 2007 12:16 AM
remote control motorised control for volume pot/knob CharlesY Parts 0 25th July 2005 12:12 PM
Copyright ©1999-2017 diyAudio
