Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Another project, all digital DDX amplifier
Old 29th January 2013, 10:09 AM   #391
soundcheck is offline soundcheck  Germany
soundcheck's Avatar
Originally Posted by Sandor View Post
I find strange that the datasheet does not contain a power/distortion diagram. The only indication is the peak power when the amp starts to hard clip (10% distortion). Which rms output power could we expect at a reasonable distortion, say 0.5% ?
@Soundcheck
1) Wich power supply do you use? Is it better to feed the DDX320 with a power transformer (AC) or a SMPS300R (DC)? Do you think a linear power supply would provide improvements in sound?
2) In your blog you suggest to add a transformer to the spdif inputs, but looking at the schematic I found that the DDX320 already has those input transoformers. Do you mean the additional spdif inputs directly connected to the receiver through the CN1 connector?
Thanks a lot.
1. I'm still using my good old 24 very low ESR (2 mR) batteries.
I do have some other 24 supplies around.
2. There is no transformer I'd be aware of.
HifiMeDiy told me, that they skipped it because of single ended WM8805
inputs.
Old 29th January 2013, 06:56 PM   #392
Paulkouhan is offline Paulkouhan
Originally Posted by soundcheck View Post
I also run (on the DDX V1) aircoils from Mundorf, which are still my favourites,
though more expensive.
Hello,
what Mundorf coil can we use for the DDX320 ?
I dont find any Mundorf 0.01mH ??
Old 31st January 2013, 12:42 PM   #393
Bill poster is offline Bill poster  Thailand
Bill poster's Avatar
just discovered this 2.1 board and want to use it in a 2.1 design I'm developing updated_wmd.jpg
I have NO real experience with electronics so will get a pro to do that part of the install, but what reasonably inexpensive power supply would you guys recommend (to fit inside the sub)
PS Soundcheck, following this thread.. you are obsessed (in a good way)
Old 31st January 2013, 01:10 PM   #394
soundcheck's Avatar
Originally Posted by Paulkouhan View Post
Hello,
OFC-foil-copper air-coils (wooden core) - 28mm
I called them up. They produce low values on request.
Old 7th February 2013, 10:39 AM   #395
raschaa is offline raschaa  Germany
Hey,
my remote has become very erratic and I have a hard time controlling the thing. Regardless of which button I press I almost always change EQ settings other remote controlled features are more or less inaccesible at the moment.
@ Soundcheck, did you get anything working with the codes? Support sent them to me but I haven't the slightetst clue what to do with them at the moment.... would it be possible to program a Harmony remote (for example)?
Old 7th February 2013, 11:39 AM   #396
soundcheck's Avatar
Originally Posted by raschaa View Post
Hey,
No. They were useless for my purposes.
I recorded the codes directly from the remote on my Linux machine using lirc.
Old 8th February 2013, 08:25 AM   #397
would you happen to have a lircd.conf of the codes?
Old 8th February 2013, 09:15 AM   #398
soundcheck's Avatar
I handed them over to the lirc database. I'll check if and when they'll be available.
Cheers
Old 8th February 2013, 01:49 PM   #399
soundcheck's Avatar
I was just informed by a fellow DIYer that HifiMeDIY released an updated DDX a V2.1.
I had a quick look at the image he sent over.
On a first glance they improved
* the routing/traces/part locations.
* decoupling
* introduced Pana FCs all over the place (except the large buffer caps)
* 2 Pulse pulsetransformers for SPDIF-coax
* clock looks much better implemented.
Looks as if they're listening.
@DiyHiFiMe: Would have been nice of you to send over a production sample for testing ...
I hope next time...
... since IMO two major issues are still not adressed:
1. better output coils and the coil mounting
2. switchable (internal/external-header) 3.3V supply option to be able to replace easily the real mediocre DC/DC converter and filter parts surrounding it.
3. (option) A clean DC only input without diode in the trace.
One thing I noticed is that the MCU seems to be moved closer to the center of the board. Hmmh. I would have done it the other way around. I'd try to get that part as far away from the audio critical parts and traces as possible. And if possible I2C lines might get isolated.
Cheers
Old 8th February 2013, 02:46 PM   #400
is kind of sad that the early adopters always turn out to be the better beta testers
Another project, all digital DDX amplifierHide this!Advertise here!
Anyone interested in a digital amplifier project? Rookie Class D 552 24th September 2014 08:29 PM
Apogee DDX EB-2060S 2x35W digital amp evaluation board ungie Swap Meet 5 20th May 2009 09:44 PM
Ddx-8001 cac liu Class D 2 9th July 2007 05:03 PM
Copyright ©1999-2017 diyAudio
