Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Another project, all digital DDX amplifier
Old 12th March 2012, 01:51 PM   #301
soundcheck is offline soundcheck  Germany
soundcheck's Avatar
I managed to get my friends spare amp tweaked. It's singing now.
I still need to fix my own amp though.
I pretty much redid everything I had done on my broken amp except that I didn't touch the 3rd channel output setup (relay and coils).
I was wondering what happened when I removed the last channel 3 relay and coils on that broken amp.
I guess the amp didn't like that open environment.
HifiMediy - It would be nice if you could speculate what could have happenend when I remove all relays and leave a output coil open on the 3rd channel.
Anyhow. I still got some questions.
What I figured now:
If I'm running 16/44.1 material I can hear into a decent noise floor.
The known flaw sounds from my experience different than that.
Still - I consider the noisefloor too high.
If I turn the volume down digitally on my Squeezebox. The noise level stays rather constant. Not what I'd call highend sound.
However. I noticed that I do not experience this -- at least that obvious -- on 24/96 material.
What I did then. I upsampled some 16/44.1 reference files with sox:
sox -D -i file4416.flac -t flac -e signed -b 24 -C 0 -o file2496.flac rate -v -I -b 97 96000
Usually upsampling is causing signal degradation. I've never achieved satisfactory results.
In this case though resampling seems to be the much better compromise.
It's really like taking a towel away.
Does anybody has an explanation at hand???
Afaik the CS8416 is doing 96k resampling on everything that hits the input.
Can anybody conform that??
Could it be that this chip is not performing that well on doing the 4416 resampling job???
I've also seen that the the 320 oversamples on 44.1/16. on 24/96 it doesn't (kind of advanced NOS setup ) .
Of course this wouldn't have any impact if the CS8416 delivers constant 96k anyhow.
Any hints to understand respectively improve the situation are appreciated.
I'm still not giving up on that device.
Cheers
Old 14th March 2012, 12:13 PM   #302
soundcheck's Avatar
It's me again.
There's a weired behaviour of the amp.
1.
If I switch from 44.1 to 96 I hear the relay clicking.
The other way around 96 to 44.1 it's not clicking.
That's when the noise starts. Do I miss a CS8416 device reset??
Am I right to assume that if the CS8416 gets resetted, the relays are activated!?!?
And can that happen while switching songs with different samplerates.
2.
I do also think when loosing SPDIF lock from the source the noise starts
after relocking. ( I have to check if that also happens during standby!!)
HifiMediy: I'd suggest to check the resetting scheme of the CS8416 and the other involved chips. I got the strange feeling that something is wrong in that area.
While searching after the issue I read somewhere that the older 8414 had in fact problems in that area (lock/samplrates/reset).
I'm not sure though if that applies to the 8416 as well.
Cheers
Old 14th March 2012, 01:57 PM   #303
soundcheck's Avatar
I'll keep talking to myself.
CS8416 datasheet:
Reset (Input) - When RST is low, the CS8416 enters a low power mode and all internal states are reset.
On initial power up, RST must be held low until the power supply is stable, and all input clocks are stable in frequency and phase.
For how long do you keep RST low?
What happens if input clocks ( The "locked" SPDIF signal itself? ) change in phase and frequency. In cases where you loose sync to the source due to whatever reasons ( reset/powerdown of source/ hook up cable etc./data corruption/sample rate change)?
Even if the DDX is in standby the SPDIF keeps locked according to the SPDIF LED. What happens if things get unlocked (source down) during standby and than while being locked down you wakeup the DDX device and than you start playing again??
The earlier mentioned relay event when switching SR is another odd event. To me at least.
As you can see. I suspect some problems in the initialization area of the CS8416.
Let see. Perhaps there is at least some interest out here to get this device to work properly.
Old 30th March 2012, 08:01 AM   #304
soundcheck's Avatar
Hi folks.
Been away for a few days.
Do I understand it correctly that Hifimediy doesn't seem to be interested to answer or discuss any of the isssues or questions related to their product anymore!?!?
I mean. It's their own vendors froum.
What a pity.
Though, I don't give up on it... ...yet.
In case you guys (hifimediy) read this:
1.
If you've got a new version cooking in the kitchen, please consider
reviewing the choice of SPDIF receiver chip.
As an alternative the WM8804 seems to come with much better jitter specs.
2.
It would be nice if you could introduce an I2S header.
This way all those USB/I2S interfaces can be used to feed the amp directly without the need to go via SPDIF.
Thx.
Old 2nd April 2012, 02:45 PM   #305
hifimediy is offline hifimediy  China
Hi, soundcheck.
Thanks for your sharing and I will consider your points. I'm sorry that I can't take much time on this board recently but I really find something interesting when reading your feedback. So, thank you
Old 6th May 2012, 02:41 PM   #306
redjr is offline redjr  United States
Originally Posted by hifimediy View Post
Hi all, I got the pcb and here is the first board.
Hey hifi - Is that a touch screen you're using with this project? That's way cool if you are.
Old 6th May 2012, 02:50 PM   #307
Originally Posted by udailey View Post
Love it.
Probably LCD would be nice on a board smaller than it or same size so we can mount it easier. I agree with the other guys.
Uriah
I love the LCD screen too! I'd take it one step farther. There's a cool 2.8" color touch screen that's got the same form factor as the Arduino. Using the Arduino as the dev platform, with a touch screen you could use your finger to adjust the volume and other parameters that act as variables. Way cool. Now I'm excited!
Old 20th May 2012, 09:52 PM   #308
oliviermallet is offline oliviermallet
Default New ST ships
Have you heard of new ST ships :
- All in one STA382BW STA382BWS - STMicroelectronics
- New driver STA309B STA309B - STMicroelectronics
- New power schip STA510F STA510F - STMicroelectronics
STA328BW & STA309B have user programmable biquad, up yo ten per channel for STA309B, so you can thrue your minidsp away ! No FIR yet, but maybe ST plan to add FIR in the next generation.
Futur is all digital.
Hifimediy, do you plan to use them ?
Old 5th June 2012, 11:30 AM   #309
soren5 is offline soren5  Denmark
But we also have more powerful chips, when sta510 or 517B used, we can handle down to 2ohm speakers.
What's the minimum impedance load of the current DDX320 (subwoofer amp)? Can it handle 2 ohm? If not, are there any plans about implementing sta510 or 517B in the future?
Old 5th June 2012, 11:39 AM   #310
Kjeldsen is offline Kjeldsen  Denmark
MiniDSP have shown they can do DSP, and hifimediy that they can do amps. Maybe it would be more beneficial if hifimediy and MiniDSP made some collaboration, and made a configuration so a hifimediy amp could connect to miniDSP via I2S.
Another project, all digital DDX amplifierHide this!Advertise here!
Anyone interested in a digital amplifier project? Rookie Class D 552 24th September 2014 08:29 PM
Apogee DDX EB-2060S 2x35W digital amp evaluation board ungie Swap Meet 5 20th May 2009 09:44 PM
Ddx-8001 cac liu Class D 2 9th July 2007 05:03 PM
Copyright ©1999-2017 diyAudio
