Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Another project, all digital DDX amplifier
Old 11th August 2011, 03:38 PM   #241
Mitch311 is offline Mitch311  Australia
Sounds most excellent. Now I just want to buy one
I just wanted to add, thank-you Hifimediy for listening to us as both potential customers and eager hobbyists. Personally I have never had interaction of this kind with a designer/manufacturer before. To know my opinions have not only been heard, but taken into account in the design of an item that I now want to purchase is refreshing. So thank-you and keep it up!
Old 11th August 2011, 11:46 PM   #242
SoldierAnt76 is offline SoldierAnt76  United States
Indeed.
That said, it's been a year since you first announced this project, so people are getting anxious.
Old 12th August 2011, 07:30 AM   #243
hifimediy is offline hifimediy  China
Basic functions for DDX320 board, update
1. S/PDIF signal (Optical and Coaxial) input, 192kHz24bit acceptable and 96kHz24bit processing.
2. Input source switch by pressing button of rotary encoder, with LED indicate.
3. Standby (power down) mode enter/exit by long press(about 3sec.) the button.
4. Rotary volume control, from -127dB to 20dB(1dB/step). with 5x LED level display.
5. User configure data auto saving when power down.
6. Output relays for speaker protection when output DC.
7. Output relays delay to turn on/ instant off when power on/off.
8. On board 3rd channel(sub-woofer) cross over frequency setting(by 4x DIP switches). 80~360Hz with 20Hz/step. And pass through option(all switch on).
sw1 sw2 sw3 sw4 FRQ
off off off off 360Hz
on off off off 340Hz
off on off off 320Hz
on on off off 300Hz
off off on off 280Hz
on off on off 260Hz
off on on off 240Hz
on on on off 220Hz
off off off on 200Hz
on off off on 180Hz
off on off on 160Hz
on on off on 140Hz
off off on on 120Hz
on off on on 100Hz
off on on on 80Hz
on on on on pass through
9. 3rd channel (sub-woofer) volume saperately controlled by pressing the button and rotary.
10. Configure the data to be default by pressing the button when power on.
Old 12th August 2011, 09:28 AM   #244
Sounds good! Basic, simple and provides the functions needed.
When can we buy one?
Old 12th August 2011, 09:55 AM   #245
pls contact nick for order.
The first batch of DDX320 will have about 10pcs.
Old 4th September 2011, 12:14 PM   #246
Nisbeth is offline Nisbeth  Denmark
Nisbeth's Avatar
Any chance of adding a remote volume option?
What would really make this brilliant would be if there was remote volume option and it used (or could learn) the codes sent by the remote for the Cambridge Audio iD100 (vol up/down, source, mute). Then you could build a fully-digital 2.1 system with remote control that would take up very little space and use an ipod as source with an option of adding a second digital source as well
/U.
PS: Probably a bit late to ask for this now, especially since I just pre-ordered a board but still...
Old 5th September 2011, 07:50 AM   #247
Kjeldsen is offline Kjeldsen  Denmark
Price incl intl shipping?
hifimediy.com is very slow from denmark at the moment, so I can't see if you have already a price in you webshop.
Old 5th September 2011, 08:26 AM   #248
BlueFusion is offline BlueFusion  Australia
+1 just found this thread and I want one
O2 amp Australian parts GB
Interest form-----Thread-----Spreadsheet - CHECK YOUR ENTRY
Old 5th September 2011, 10:56 AM   #249
here is some nice toys too
Buy 2.1 OR 3 WAY DSP AMP, CLASS D, 300W, DSP+TAS5630+SMPS 2.1 OR THREE WAY HI-FI AMP WITH ANALOG/SPDIF/USB SOURCE SELECTOR at Aliexpress.com
Old 6th September 2011, 03:52 AM   #250
Something wrong with the website last days. I think you can see the price now.
Another project, all digital DDX amplifierHide this!Advertise here!
Anyone interested in a digital amplifier project? Rookie Class D 552 24th September 2014 09:29 PM
Apogee DDX EB-2060S 2x35W digital amp evaluation board ungie Swap Meet 5 20th May 2009 10:44 PM
Ddx-8001 cac liu Class D 2 9th July 2007 06:03 PM
