Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Another project, all digital DDX amplifier
Old 18th July 2011, 12:10 PM   #221
hifimediy is offline hifimediy  China
Originally Posted by AlexScan View Post
I know that, but if I have 3 or 4 IS signal pre-filtered (for example with this multichannel I2S board), how I can connect the different Tripath board in PWM mode ?
hi, I think that will be another product. We can build some board with I2S inputs then you can use it. but I prefer make the decoder and DDX together, which means we will have a S/PDIF or USB input and output multi-channels. Because I2S signal is sensitive that not recommended to travel long.
Old 18th July 2011, 12:34 PM   #222
Basic functions for DDX320 board:
1. S/PDIF signal (Optical and Coaxial) input, 192kHz24bit acceptable and inner 96kHz24bit processing.
2. Channel switch by pressing button of rotary encoder, with LED indicate.
3. Long press button to enter standby (power down) mode, and again exit.
4. Rotary volume control, from -127dB to 20dB, 1dB/step. with 5x LED level display.
5. Setting data auto saving when power down, and restore when power on again.
6. Output relays for DC protection. And relay to turn on/ instant off.
7. On board 3rd channel cross over frequency setting(by 4x DIP switches). 80~360Hz with 20Hz/step. And pass through option.
anything I missed?
Old 19th July 2011, 05:45 AM   #223
SoldierAnt76 is offline SoldierAnt76  United States
anything I missed?
Is the "rotary encoder" you mention in #2 the same as the "rotary volume control" in #4? If you're using just one control for both power and channel selection, people might get confused - e.g., accidentally switching channels when they want to power down, or turn up the volume.
About #5 and #3 - will the settings be saved if there's a cold shutdown (i.e., power is completely disconnected), or only when the unit is in standby (i.e., the unit still consumes a trickle of power, even though it appears to be off)?
Old 19th July 2011, 09:07 AM   #224
AlexScan is offline AlexScan  France
It's possible to add a second "sub out" for make a 2.2 DDX ?
Old 19th July 2011, 12:01 PM   #225
Hi, yes we use one rotary to control. And there is no trouble because when control volume, we turn it, while channel switch we press it. If long press(about 2sec), it will be be a power down/on function. That is what we do on VC23 board.
And sure, it will remember the settings when cold off.
no now, it's just 2.1.
Old 19th July 2011, 04:10 PM   #226
My guess is that most people won't be switching channels often, and quite a few (myself included) will use a separate power switch wired to the SMPS for on/off instead of the standby function. But as long as the knob can't be pressed accidentally, it's probably okay.
How soon will units be available for sale?
Old 19th July 2011, 05:19 PM   #227
Ok but it is not possible to connect the 0.1 channel to two amplificator in PWM mode ?
Old 20th July 2011, 01:31 AM   #228
I'm preparing the first batch, and soon you will find it on hifimediy.com.
Old 20th July 2011, 01:35 AM   #229
Yes we can do that. The 0.1 channel we use an sta508 (mono mode) to drive now, and can drive 4ohm, or 2X 8ohm in parallel.
Old 20th July 2011, 08:36 AM   #230
Ok the power chip was include inside the board !!!
This is not good for me I have two 4Ω/10" speaker for the bass in my system
Another project, all digital DDX amplifierHide this!Advertise here!
Anyone interested in a digital amplifier project? Rookie Class D 552 24th September 2014 08:29 PM
Apogee DDX EB-2060S 2x35W digital amp evaluation board ungie Swap Meet 5 20th May 2009 09:44 PM
Ddx-8001 cac liu Class D 2 9th July 2007 05:03 PM
Copyright ©1999-2017 diyAudio
