Dispre II PCBs available
I would use my stepped attenuator anyway. I have a nice 46 step now which i use in a "passive"pre amp.
So when using single ended:
1) For my pre amp, fully balanced i would need two SE boards and 1 PSU.
2) For my headphone amp i would need 1 SE board and 1 PSU
Can you also supply the matched FET's with the PCB's? How can i order?
regards,
Harold
regards,
Harold
Yes, I can sell the matched JFETs as well. Right now, even my SE PCB stock is getting empty. I will order new boards immediately after 1st of January.
To place an order, please send me an e-mail (on my web page or thru PM here /I have only e-mail PM activated/). I will let you know when the boards are produced.
Thanks,
Pavel,
did you ever use the ALPS in shunt mode with these boards. Would also be an advantage for the balanced boards, you would only need a stereo ALPS. I do this in my cross over, works very well and pot is not in signal line.
Looks like this
(+)IN---R1---------R1 ---OUT(+)
R2 (id needed depends on pot)
10k ALPS
(-)IN---R1---------R1----OUT(-)
regards,
PS the ALPS is now replaced by a stepped attenuator because the channel matching of the ALPS is not good enough for me.
Harold
