Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Tas5630+smps+aluminum case finished!new year coming!
Old 29th June 2014, 09:18 AM   #441
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Tas5630+smps+aluminum case finished!new year coming! Send a message via MSN to authlxl
Originally Posted by authlxl View Post
G300v33BTL and G300V33PBT module completed!
PROAUDIO TO HI-FI VERSION
STABLE AND EXCELLENT SOUND
Very stable version, shorted output together anytime no problems.
Dynamic limiter support,
DCP /OCP/ UVP/OTP protections, even POWER LEVEL control system added, this function can make the module RMS power about 400W total.so the chip can run under safe conditions.
Key benefits
Backup DC supply system, suit for solar or car system application.
A wide set of features for plug and play implementation into applications such as active speakers or proaudiosystem.
Black-box design, module have good heat dissipation and better EMC performance.
Advanced protected function against short circuits, overload and overheating and includes on-board fuses and EMI filtering that provide a CE and FCC pre-approved design.
Key Specifications
.POWER OUT:
G300v33BTL 2200W/ 4Ω@1%THD+N /2 BTL MODE
G300v33PBT 1X350W /2 Ω @ 1% THD+N /1PBTL MODE
.FREQUENCY RESPONSE: THD+N ≤0.05% / 20-20KHz / <1dB/1W
.INPUT SENSITIVITY: 0dBV(1Vrms/BAL input)
.S/N: 98dB(AES-17/A-weight)
.POWER SUPPLY: 110VAC OR 220VAC 50 OR 60Hz
.AUXILIARY POWER: +/-14V @ 500MA max
.DIMENSIONS: 160MM(length)*80(width)*52mm(height)
.NET WEIGHT: 0.46Kg
Key Features
Balance input and balance output design, Hi-Fi sound design
Multilayer PCB and thickness copper route
Dynamic limiter inside, suit for proaudio system
Black-box design, high power small size
Multi current protection and auto reset system
Clip signal indicator
channel PWM running status have led indictor
Suitable for CE approved designs
Proaudio system To Hi-Fi design
SYSTEM TESTING
PROTECTION TESTING
Output shorted testing passed
Shorted output wire while half loader running , , good protection performance.
No loader and amp running . 1vrms and 1khz signal added, shorted output, protect well.
Over load testing passed
Add 1khz signal and connect 2ohm loader, increase the input gain , if loader power over 400W, SMPSOCP protect will happen, it isconstantprotection.
AP testing below
Sample link below, only accept wholsale order, mass order please conntact our sales.
Aliexpress.com : Buy TAS5630 AND SMPS AII IN ONE BOARD from Reliable smps power supply circuit suppliers on SINEWAVE SAMPLE STORE
PA and Ultransonic :SINEWAVE MAINLAND
Professional Audio:SINEWAVE OVERSEA
Made-in-china:SINEWAVE.MADE-IN-CHINA
Old 30th June 2014, 01:58 PM   #442
Default G300V33 THD VALUE
Update G300v33 THD value.
Old 4th July 2014, 07:09 AM   #443
G300v33BTL and G300v33PBT have stock now, mini order quantity is 10 unit every order, 120usd/unit,if order more ,please connect out sales. sales @csinewave.com
Old 5th July 2014, 12:56 AM   #444
G300V33BTL LINK:
Aliexpress.com : Buy DSP+CLASS D AMP+SMPS 2.1 OR THREE WAY HI FI AMP WITH ANALOG/SPDIF/USB SOURCE SELECTOR from Reliable amp pc suppliers on SINEWAVE SAMPLE STORE
G300V33PBT LINK:
Old 27th August 2014, 04:47 AM   #445
electra_ina is offline electra_ina  Indonesia
electra_ina's Avatar
I need SMPS like this attachment..
How much price include to Jakarta, Indonesia
Thanks before
Old 27th August 2014, 01:15 PM   #446
Thanks before
Thank you for your reply here, please order it in our sample store, if order more than 100units, please send mail to sales@csinewave.com
Aliexpress.com : Buy 800W PFC +SMPS POWER SUPPLY , SUIT FOR 2STAGE CLASS H AMP from Reliable power supply dc to dc suppliers on SINEWAVE SAMPLE STORE
Old 17th September 2014, 02:48 PM   #447
Kjeldsen is offline Kjeldsen  Denmark
Do you plan any open loop digital amps?
TAS5162 | Mid/High-Power Amplifier | Speaker Amplifier and Modulator | Description & parametrics
Old 17th September 2014, 03:28 PM   #448
Smile car all digital 2.1 amp
Originally Posted by Kjeldsen View Post
what a coincidence! our engineer send took two new board photos just now, it is all digital car amplifier design, second version boad debugging now.
Features:
1.All Digital amplifier, use TAS5558+2 TAS5631B+4PHASE DC to DC .
2.10-15VDC input, 150WX2+400WX1 rms power output
3.Support distance remote function
4.Support Spdif and USB audio input
This project will be closed next week,you can send mail to us for the order.
Old 17th September 2014, 03:48 PM   #449
Default 250w RMS power 100v output transformerless amp module complete
1.250W mono PA amp, RMS power @ 100V transformerless output
2.220V or 110V ac supply selected
3.1u height,330mm(L)X40mm(H)x51mm(W)
4.Self test function, amp have auto self test function, and report amp status to RS485 .
5.RS485 remote standby and mute function.
6.Perfect protection function, High stablity.
Old 17th September 2014, 03:55 PM   #450
Default 4kw rms class D 100v output transformerless amplifier completed!
Customer design one new board , 4KW rms power 100v output , transformerless PA amplifier, Amp case manufactruing now.
robust design, have pass all shorted test and 24hour full resister load testing.
Board size:380mm(L)x300mm(W)x75mm(H)
Tas5630+smps+aluminum case finished!new year coming!Hide this!Advertise here!
Hypex SMPS - When Is It Coming? Alternatives? theseum Class D 212 26th April 2009 02:10 PM
nice aluminum case cowanrg Swap Meet 5 6th September 2007 07:42 PM
Aleph-X finished... one year ago !!! GlouBou Pass Labs 6 30th June 2006 04:40 AM
Finished my Maelstrom Sonotube after almost a year of work kingdaddy Subwoofers 20 10th January 2004 11:03 PM
