Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Tas5630+smps+aluminum case finished!new year coming!
Old 18th August 2013, 01:27 AM   #391
mikey_audiogeek is offline mikey_audiogeek  New Zealand
Originally Posted by authlxl View Post
Thank you for your reply, if met background noise ,you can try the way to connect heatsink to earth ,you know it need three wire for common application,safety and quiet,we can provide two new board next week.
G300V31: 500W SMPS+ Tas5630B or TAS5613A
G300V31D: 500W SMPS+ TAS5548+tas5631B, it is I2s input, and support TI PurePathTM Console graphic software realtime download,it is stereo amp and new type all digital board , welcome friend to try it and give us more suggestions.
I would like to try the TAS5548/TAS5631B amplifier, please let me know cost and delivery details to New Zealand.
I already have PurePath Console on my computer, and I also have a TAS5548EVM.
Thanks!
Mike
Old 18th August 2013, 01:29 AM   #392
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Tas5630+smps+aluminum case finished!new year coming! Send a message via MSN to authlxl
Thank you for your reply here, better price for you, pls mail to us, authlxl@gmail.com
Originally Posted by PandazYa View Post
what would be the price of your tas5631b boards?
PA and Ultransonic :SINEWAVE MAINLAND
Professional Audio:SINEWAVE OVERSEA
Made-in-china:SINEWAVE.MADE-IN-CHINA
Old 18th August 2013, 01:31 AM   #393
Thanks!
Mike
Old 18th August 2013, 01:45 AM   #394
Thank you Mr Lai, I have sent you an email.
Best regards,
Mike
Old 18th August 2013, 02:10 AM   #395
Reply mail sent.
Best regards,
Mike
Old 19th August 2013, 11:49 PM   #396
Taterworks is offline Taterworks  United States
Taterworks's Avatar
I appreciate the input. Please understand that my review is for the older G300V21 module, not the newer G300V30 or G300V31 boards. I will need to listen to one of the newer boards to comment on how they sound. My G200 amplifier was electrically grounded to the same ground connection as my preamp and CD player.
I will be in contact with you soon about how to order a G300V31 board with TAS5613A.
Another area where Sinewave could improve their product line is to offer the SMPS and the amplifier section as separate modules, which could be combined by amplifier designers in a single chassis as needed. The modules could be available in stereo and PBTL mono configurations to suit a wide array of applications. This is similar to what is currently offered by Hypex
I cannot agree more with your statement here! I think they would sell even more of their boards this way
I think the following complement of modular products based on TAS5613/TAS5630 would perform very well in the market:
500W Audio SMPS board: Same SMPS as currently on the board for G300V31, for driving one stereo or one PBTL amplifier module.
1200W Audio SMPS board: For driving two TAS5630B-PBTL amplifier modules (providing 600W each), or one TAS5630B stereo amplifier module where extreme high current is needed for improved bass.
600W Linear Audio PSU board: Linear power supply for use with 600VA transformer of proper secondary voltage to supply power to amp modules - includes rectifier bridge, filtering capacitors, and reservoir capacitors for driving one TAS5613A stereo module, one TAS5630B stereo module, or one TAS5630-PBTL mono module.
TAS5613A Stereo Amp Module (No PSU): Component selection same as the amplifier section of the G300V31 board but with TAS5613A chip - requires external PSU
TAS5630B Stereo Amp Module (No PSU): Component selection same as amplifier section of the G300V31 board but with TAS5630B chip - requires external PSU
TAS5630B-PBTL Mono Amp Module (No PSU): Component selection same as amplifier section of the G300V31 board but with TAS5630 chip configured for PBTL - requires external PSU
Provide 0.250 fast-on connections between boards for DC power and speaker output, not molex type - this will make the products easier to use for DIY customers, while industrial customers can still use them easily. My big complaint with the ICEpower boards is that I can't assemble the wire harness connectors, so the way Sinewave currently does it is better. I also prefer the way the heatsink is an aluminum plate on the bottom of the Sinewave modules so they can be mounted to any aluminum surface for heat transfer. This seems like the best way to provide the needed heat transfer for the SMPS and the TAS5630 chip. It is a good, smart design.
That is how I think a line of modular amplifier components could be set up. These modular products should be offered together with the existing complete G300V31 modules to allow amp designers to create the solution that their project needs by combining modules.
If it works, but you don't know why it works, then you haven't done any engineering.
Taterworks Audio (nothing for sale)
Old 29th August 2013, 09:44 AM   #397
Default G300VV31 V2.0 UPDATE
Long time testing , G300v31 boards are manufacturing now.latest version is v2.0 now
two chip version TAS5613A and TAS5630B
TAS5630B version specifictions:
1. full 400W rms power out one module.
2. Half bridge LLC power supply .
3.Shield output inductor and very few influence to radio.
4. 2channel output:
2x200W/4ohm@0.5%THD+N
2X300W/4ohm@10%THD+N
5. 1channel output:
1X400W/2ohm@1%THD+N
6. Balance signal input.
7. Every channel work status indictor
8.Clip signal indicator
9.110v or 230V ac supply
10. AC supply fuse on board
11.8mm thickness aluminum plate heatsink, 2X3mm assembling hole support.
TAS5613A version specifictions:same board as TAS5630B
1. full 400W rms power out one module (@3ohm loder).
4. 2channel output:
2x120W/4ohm@0.5%THD+N
2X150W/4ohm@10%THD+N
5. 1channel output:
1X250W/2ohm@1%THD+N
Old 29th August 2013, 10:09 AM   #398
Default G300V31D UPDATE,TAS5548/TAS5558+TAS5631B
TAS5548/TAS5558+TAS5631B circuits testing finish now, works well , latest version G300V31D V1.2 .
Suppor TI pure path console software, customer can adjust it's EQ/LIMITER/MIXER/INPUT OUTPUT CHANNEL real time and download to board, it support alone runing function, if press download key on board , all the parameterS will be wrote to EEPROM and can run as your set when power on.
Specifications:
1. two channel IIS digital signal input, up to 192Khz/24bit
2. USB programmer on board ,support USB audio input and output.
3. IIC control port on board,support customer program.
4. full 400W rms power out one module.
5. Half bridge LLC power supply .
6. Shield output inductor and very few influence to radio.
7. 2channel output:
8. 1channel output:
1X400W/2ohm@1%THD+N
9. Every channel work status indictor
10.Clip signal indicator
11.110v or 230V ac supply
12. AC supply fuse on board
13.8mm thickness aluminum plate heatsink, 2X3mm assembling hole support.
14.Dimensions:235mm(L)x91mm(W)x52mm(H)
15.Weight:0.88Kg
Old 29th August 2013, 10:32 AM   #399
Default DP2500 2ch multifeedback class D amp finished
DP2500 2X500w multifeedback class D amp is manufacturing now, have pass our strict test. works well now. latest version is DP2500 V1.3
Specifications:
1.OUTPUT :
2x500W/4ohm@1%THD+N
1x2000w/4om@1%THD+N
2.S/N:-101dB.
3. Frequency Response(8ohms):20-20Khz +/-0.5dB
4. Damping Factor (8 ohms): 260
5. Variable Fan cooling system
6. Full protection system:OTP/OVP/OCP/UVP/DCP.
support no loader and high load shorted output test .
7.Dimensions: 152mm(W)x250mm(L)x70mm(H)
8. Weight:1.78Kg
Old 29th August 2013, 10:41 AM   #400
Kjeldsen is offline Kjeldsen  Denmark
Specifications:
7. 2channel output:
8. 1channel output:
1X400W/2ohm@1%THD+N
15.Weight:0.88Kg
Does it support USB audio input from PC, or is it just USB programming - I think both is said in the text, so I'm a bit confused.
Tas5630+smps+aluminum case finished!new year coming!Hide this!Advertise here!
Hypex SMPS - When Is It Coming? Alternatives? theseum Class D 212 26th April 2009 02:10 PM
nice aluminum case cowanrg Swap Meet 5 6th September 2007 07:42 PM
Aleph-X finished... one year ago !!! GlouBou Pass Labs 6 30th June 2006 04:40 AM
Finished my Maelstrom Sonotube after almost a year of work kingdaddy Subwoofers 20 10th January 2004 11:03 PM
