Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Tas5630+smps+aluminum case finished!new year coming!
Old 18th October 2012, 01:31 PM   #301
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Tas5630+smps+aluminum case finished!new year coming! Send a message via MSN to authlxl
Default crown xls2000 photo
Originally Posted by authlxl View Post
Little leisure in busy SHANGHAI show!
1.SMPS CLASS H PROAMP 3000W
2.SMPS CLASS D+CLASS B PROAMP 4000W
3.MULTICHANNEL PUBLIC ADDRESS AMP 5X50W
4.NEW PUBLIC ADDRESS AMP FROM BEHRINGER
5.New type Ipad stand and record system
6.Aluminum active amp panel
7.Aluminum active amp panel
8.Live show
9.Work hard!
10.Successors will unfailingly come forth
share some crwon xls2000 photo.
PA and Ultransonic :SINEWAVE MAINLAND
Professional Audio:SINEWAVE OVERSEA
Made-in-china:SINEWAVE.MADE-IN-CHINA
Old 30th October 2012, 03:10 PM   #302
Default G36D amp going on
Compare with G33D, it is higher version .
1. all 24bit/192kHz audio stream,include USB source.
2. 2 tas5630B chip inside, ultra lower dcoffset and better sound than tas5630,
3.power out: 2X200W+1x200w or 4x200w ,
4. High-end Combo Sample Rate Converter SRC4392 support, Dynamic Range 144dB.
5.Excellent USB convertor apply.same USB convert chip as ASUS Xonar Essence One.support ASIO and WASAPI in windows system.
6.add LCD display unit, add rotary encoder volume adjustment and system control.
7.Remote controller
8. Sigma software full function support
9.auto switchable 110v or 220v switch SMPS.
10.Variable Fan cooling system inside, very low cooling noise when working
Link here to reference:
1.USB:
ASUS - Multimedia- ASUS Xonar Essence One
2. Asynchronous Sample Rate Converter :
Digital Audio Interface - Sample Rate Converter - SRC4392 - TI.com
3.TAS5630B:
Speaker Amplifier and Modulator - Mid/High-Power Amplifier - TAS5630B - TI.com
Many friends care our new G36D amp, First version have tested in last days, revised second version going on now, finished amp will come on soon.
added specs:
1.Multilayer PCB version , sound well.
2.Specific 100V or 220v auto switch.
3.dual TAS5630B chip inside.4ch or 2.1ch easy change
4.full functions remote control
5.ultra low EMI output inductor assembled, especially suit for radio signal amplify
attached first version main board and rear panel silk drawing here.
Good ideas or suggestions are welcome.
Old 2nd November 2012, 12:38 PM   #303
morphy8 is offline morphy8
New Genius member listed.G300DS is our latest Genius series AMP module, it is Hi-end products for digital source amplify .it accept two SPDIF source, two source convert by one switcher.Up to 192Khz /24bit sample rate supports.sound clear and powerful.
FEATURES:
1.TAS5630B chip full power design,high dynamic range.
2.auto reset SMPS protection OCP/UVP/OVP/OTP and AMP protection OCP/DCP/OTP.
3.Support variable fan cooling system.
4.Very low EMI design, suit for digital FM source.
SPECIFICATIONS:
1.Power out:2*150W/4Ω/0.5%THD+N(test one by one channel)
2.Input:2 coaxial SPDIF source (support switchable source convert)
3.SPDIF Sample Rate: 192KHz/24bit
4.Frequency response:20-20KHz +/-1dB
5.Loader:4Ω/8Ω
6.Ac Input:90-265VAC 50 OR 60Hz
7.Variable Fan :12VDC brushless fan
Hi Authlxl,
I probalbly have USB Audio out with my new setup (using Android Stick). Do you have an USB to Coaxial SPDIF board or box? Have seen pictures on your shop at Aliexperess but not any converter besides the digital transmitter.
I still plan to use the G300DS and build up a Power-Media-Player... ;-)
Cheers!
Andy
Old 5th November 2012, 02:00 AM   #304
Taterworks is offline Taterworks  United States
Taterworks's Avatar
I tried a Sinewave Genius G300V21 recently, and found that with some ordinary speakers, the background noise (like hiss with attenuated HF content) was audible at the listening position. It was only after I switched to a pair of very low sensitivity speakers (82dB 1W/1m) that the noise was reduced to an "acceptable" level (still audible but barely perceptible at the listening position).
IMO, these amps still need additional work to improve noise filtering before they have a place in an audiophile-level system. Noise should not be audible at the listening position in a high-quality audio system.
Other impressions: Very well-controlled bass, even a slightly over-damped sound. These amps have very little sonic signature of their own through the midrange and treble, and certainly no 'sweeteners' or added warmth. If anything is wrong with the voicing of your speakers, you will hear it with this amp. Detail and texture are excellent.
I hope that Sinewave can address the noise problem with the G300V21 implementation of the TAS5630 soon, perhaps in a new revision of the PCB, because otherwise these would be excellent amps and a great value.
Ancillary equipment: Marantz CD5004 as transport, Musical Fidelity V-DAC, Mark Levinson No. 38 preamp. With my typical mid-1990s Hafler power amp, this system is silent, with no noise audible until about 1-2" from the speakers.
If it works, but you don't know why it works, then you haven't done any engineering.
Taterworks Audio (nothing for sale)
Old 5th November 2012, 02:37 AM   #305
Default G300V21 AMP
Thank you for you reply here, maybe something error with your applying , pls try our finished G300 amp.we think you try our G300V21 module and without case.
if you heard hiss noise from speaker with our g300v21 board with normal speaker, pls check case shield, because signal input loader resister are 1Mohm, very high input impedance.we suggest you can assemble it in one case as shield.
G300V21 main specifications:
S/N > 100db
Dynamic Range>102dB
Noise voltage:28uVrms (A-weight,AES17filter)
Channel Separation: >84dB
Frequency Response: +/-0.5dB
if want to drive high sensitivity speaker, over 100db/m ,pls let us know, we have other board with very high S/N(>120dB).cost high price high.our customer use it to oil well logging, loader sensitivity>130dB.
Old 5th November 2012, 03:24 AM   #306
Default G36V1.2 pass our test!
Finally we finish our G36v1.2 amp board test,sound excellent,works stable, very low temperature rise after 24hours burning-in .
First batch finished amp will finish this week.paste some main board pics here.
Old 5th November 2012, 11:13 AM   #307
soren5 is offline soren5  Denmark
Hello,
I bought two Sinewave G300V21 modules with the intention of using them to build active 2-way speakers. Like you, I'm pleased with their clean sound and controlled bass. I also experienced the same high noise-floor as you describe, but I figured it must be related to the source or a grounding issue since the noise disappears if the source is disconnected.
However, I have another problem with the G300V21 modules. They don't switch on every time power is connected. Sometimes I have to turn them on and off five or ten times before the green light comes on. Have you experienced this problem too? I have tried to get help from Sinewave, but despite being very help, language barriers are making the communication difficult.
Kind regards,
Soren
Old 5th November 2012, 11:56 AM   #308
Originally Posted by soren5 View Post
Hello,
Kind regards,
Soren
Thank you for your reply here. G300V21 turn off and on time a bit long, about 10-30s. because it have special circuit to protect the TAS5630 chip.soft on and fast repeat reject .
we will upgrade this performance in later version, we will make G300V30 version, we will apply special SMPS and make G300V30 as ultra lower interference with radio .it is bigger upgrade.
sorry for the inconvenient!
plz give us more good suggestion about it, we are plan to make two type,one stereo output(2BTL) and the other mono (PBTL).
Old 5th November 2012, 12:30 PM   #309
Taterworks's Avatar
This is exciting news. Please take a look at the products being sold by ICEPower A/S, which also integrate a switch mode power supply on the same circuit board as the amplifier stage. The ICEPower modules are very well regarded, and their modules have a very low noise floor. If you could investigate these modules and achieve similar low noise levels with your new G300V30, it would be a great value in Class-D/switch-mode amp modules, because the sound quality was already excellent when I tested the G300V21 (even though it was slightly different from the ICEPower module). The similar module to your G300V21 is the ICEPower 125ASX2 module.
I'm interested in continuing to investigate these affordably-priced modules, and I'll probably try to get one of these G300V30 modules once they are available.
Old 5th November 2012, 12:55 PM   #310
Thank you for your reply, we will finish this task quickly!we will paste pics here when finish.
Thanks again!
Tas5630+smps+aluminum case finished!new year coming!Hide this!Advertise here!
Hypex SMPS - When Is It Coming? Alternatives? theseum Class D 212 26th April 2009 02:10 PM
nice aluminum case cowanrg Swap Meet 5 6th September 2007 07:42 PM
Aleph-X finished... one year ago !!! GlouBou Pass Labs 6 30th June 2006 04:40 AM
Finished my Maelstrom Sonotube after almost a year of work kingdaddy Subwoofers 20 10th January 2004 11:03 PM
Copyright ©1999-2017 diyAudio
