Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Tas5630+smps+aluminum case finished!new year coming!
Old 6th February 2012, 02:29 AM   #191
authlxl is offline authlxl  China
SINEWAVE ELECTRONICS CO.,LTD
Tas5630+smps+aluminum case finished!new year coming! Send a message via MSN to authlxl
Originally Posted by max7219 View Post
I thougth this is a diy forum
My amplifier is already build, but I wanted to eliminate the *speaker-plop*.
Maybe I will try the TL7712 Reset circuit.
If you would like to share your reset circuit, a pm is very appreciated.
Kind regards,
max
Our engineer tell us just ago, maybe good method ,you can try it.
Old 13th February 2012, 07:34 AM   #192
Default PFC+SMPS+CLASS d 2CH BOARD manufacturing
our new design pfc+smps +class D 2CH module are manufacturing now.
1.2X500W/4OHM/1%THD+N rms power.
2.interleaved PFC stage.
3.crystal oscillator sync signal.
4.auto limiter input signal.
5.3 point temperature detection, over temperature protect.
6.Cycle detection over current protect.
7.OVP/UVP/OTP/OCP/DCP full function protect.
8.Bridge easier.
9.auto variable temperature controlling fan cooling sysytem.
10.DSP or Analog preamp stage selected.
11.Dimensions:284mm(L)x135mm(W)x41mm(H)
Old 17th February 2012, 11:09 AM   #193
strangerinthenet is offline strangerinthenet
I am planning to buy two Sinewave G330V21 amps for a DSP based active crossover 2 way stereo speakers:
Wholesale TAS5630 HIGH POWER Hi Fi CLASS D AMPLIFIER LASTEST VERSION HIGH STABLE HIGH DISCOUNT!
based on this TAS5630 module:
Wholesale TAS5630 AND SMPS AII IN ONE BOARD
Looks like a very cost effective solution. I am not a diyer, but I want to build my definitive audio system and I am very interested in top quality. I would be very interested in having some impression on it in terms of quality/taste from someone who tested it or the board it is based on. Has anybody compared it to other modules e.g. ICEPower, ClassDaudio, Hypex etc?
One more technical question. The amp's input sensitivity is rated at 0dB/100kΩ. Would it interface well with my Minidsp 2x8 board, whose maximum output is rated at 2Vrms (8 dBu) in unbalanced mode?
Thanks in advance for your help
Oreste
Old 17th February 2012, 12:36 PM   #194
8.Bridge easier.
Dear authlxl,
when you say at point 10:
do you mean that this amp will allow for full digital input (I2S) from dsp, so no A/D conversion is needed but just D/A after amplification?
This would be very interesting to me and would make me opt for this solution instead of the genius 300V21.
Is it based on TAS5630 as well?
When will it be available?
Since 2x500 watts is quite overkill for me, are you planning to provide a lower power module anytime?
Oreste
Old 17th February 2012, 02:23 PM   #195
Originally Posted by strangerinthenet View Post
Dear authlxl,
Oreste
oh! very sorry, I mean we have two type preamp board, one preamp process audio signal with analog circuit, the other process it with DSP . all of them output are analog .we will paste more pictures here next weekend.
PA and Ultransonic :SINEWAVE MAINLAND
Professional Audio:SINEWAVE OVERSEA
Made-in-china:SINEWAVE.MADE-IN-CHINA
Old 19th February 2012, 12:15 PM   #196
I decided to buy 2 Genius300V21 for my dsp active speaker setup. The Input sensitivity of the amps is rated at 0dB/100kΩ. I do not understand what this means in terms of interfacing it with minidsp 2x8, whose maximum RCA output is 2Vrms (8 dBu) in unbalanced mode. Can anybody help me?
Is the aliexpress site:
the official authlxl web shop?
Is there any special discount for diyaudio members? I am buying 2 amps.
Old 19th February 2012, 12:17 PM   #197
I would also be very interested in having some impressions on the sound quality/taste of the TAS5630 board. Has anybody compared it to other modules?
Old 20th February 2012, 02:55 AM   #198
Oreste
if input level higher, pls tell us when order, we will change some parts suit for your application.
Old 20th February 2012, 02:57 AM   #199
you can search it in class D forums, here is commercial sector.
Old 20th February 2012, 11:35 AM   #200
Default sorry
You are right, I am sorry. I didn not realize it was a commercial section.
Anyway, you did not tell me if the minidsp out of 2v is right for your amp.
What is the input sensitivity of the amp? Can it be adjusted on board (in case I want to add xlr)?
Thanks again
Oreste
Tas5630+smps+aluminum case finished!new year coming!Hide this!Advertise here!
Hypex SMPS - When Is It Coming? Alternatives? theseum Class D 212 26th April 2009 03:10 PM
nice aluminum case cowanrg Swap Meet 5 6th September 2007 08:42 PM
Aleph-X finished... one year ago !!! GlouBou Pass Labs 6 30th June 2006 05:40 AM
Finished my Maelstrom Sonotube after almost a year of work kingdaddy Subwoofers 20 11th January 2004 12:03 AM
Copyright ©1999-2017 diyAudio
