Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Where are these caps used?
Old 18th May 2009, 04:39 PM   #1
MCampbell is offline MCampbell  United Kingdom
Default Where are these caps used?
Was having a bit of a rummage through some out-of-date electrolytics, and came across a few of these:
(see pic)
They're 7500uF + 7500uF dual section electrolytics @ 25V
I've dug around, and apart from one uninformative catalogue reference and one Google hit on someone selling some NOS ITT parts of the same value, I can't find out anything about what equipment they were originally used in.
The ones I found were from 2003, so there must have been some ongoing use for them.....
Someone must know....!!!
Any information gratefully received.
Matt
Old 18th May 2009, 05:02 PM   #2
Minion is offline Minion  Canada
These dual section electro"s are probably used in The Power supply of an amp or simular , they could also be used as the output caps in a lowish powered single ended amp , or really anywere you need a 7500uF electro....
Cheers
Old 19th May 2009, 01:25 AM   #3
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
i am guessing that the connections are two positive leads and one negative lead. if so it would probably be for a dual power supply, like a +12/+5V supply, or for a pi section filter with a choke between the two positive terminals, the power supply on one side and the load on the other.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 19th May 2009, 01:27 PM   #4
riktw is offline riktw  Netherlands
hmm, high power power supply's, i have seen stuff up to 20.000uF in an 12V power supply.
class A amp's of 10~20 watts normally need 20V and -20V, maybe from something like that.
so anything that needs high current and a low voltage.
Old 19th May 2009, 01:44 PM   #5
Thanks chaps - really interesting responses.
One further question:
Does anyone actually design in high uF/low voltage dual sections like these anymore (apart from for neatness when replacing one in an old PSU)?
Old 19th May 2009, 02:48 PM   #6
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Afaik, Fischer & Tausche used to be the only remaining manufacturer of low voltage dual section electrolytics on this (in)continent in 1K9.
Their LFAX is a general use 105C type, mainly to save space, same goes for the higher voltage LFAZ range.
Electrolytics have become much smaller, no use for duallies i suppose.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Where are these caps used?Hide this!Advertise here!
Silver Mica caps VS Polystyrene caps KevinLee Parts 41 11th November 2015 03:38 PM
bypass caps for bypassing mylar caps? crippledchicken Multi-Way 4 27th February 2008 05:24 AM
Replacing multi-section caps with multiple caps? Sir Trefor Parts 1 29th May 2007 11:17 PM
Replacing ceramic disc caps with silver mica caps? G Solid State 5 18th November 2002 02:02 PM
FILM Caps to assist Big ELYT Caps gromanswe Parts 0 9th July 2002 09:16 AM
Copyright ©1999-2017 diyAudio
