Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
NEW Audio amplifier kits, modules and many others.
Old 23rd October 2009, 03:55 PM   #501
Cristi is offline Cristi
Banned
i want to repeat for everybody who try to contact me, from security reasons to NOT USE THE SAME EMAIL ADDRESS AS THE PAYPAL ONE, but the one hosted by gmail. i do not get mails on the paypal address and not reply from that address.
Old 24th October 2009, 06:33 AM   #502
ashok is offline ashok
ashok's Avatar
Default IRAudAmp7
Hi CNX,
How does one scale up the IRAudAmp7 for higher power. Is it just by raising the supply voltage ? Does it need additional power transistors and change in some component values ?
Hope you will have the correct Singapore address on my shipment and send it soon. My friend will be coming over here soon and it needs to get to him on time.
Thanks.
Ashok.
AM
Old 24th October 2009, 05:28 PM   #503
ashok's Avatar
I just found the IRF PDF paper on the IRAudAmp . So I think I get it. No additional transistors but a change to a higher rated one and a supply change. You are supplying the one rated to 150 watts. Do you also have the IRFI4020H-117P transistors. How much are they ?
cheers.
Ashok.
AM
Old 25th October 2009, 11:10 AM   #504
Jack musician is offline Jack musician  Canada
hi,cnx,do you think tripath chips like tda2500 and ta 3020 are still in production or
if they are only available still out of stocks?
Old 27th October 2009, 03:36 PM   #505
Banned
Tripath chips are out from production since the company closed 2 years ago. but there are some stocks available for this chips right now. probably in the next years they will be just history if the company who purchased Tripath and their IP will not continue development and production. until now there is no sign that they are interested to do this.
Old 29th October 2009, 06:40 PM   #506
Banned
new product added: Connexelectronic
250W power supply suitable for TA2022 and TDA892x modules. i'm playing with one of them right now, and they will be available for sale starting from monday.
Old 29th October 2009, 06:51 PM   #507
Banned
Default TDA892x v2 Module with heatsink pictures
i made some photos of the new TDA892x module, with the heatsink which is available as an option for this amplifier. the heatsink measures 58x30x70mm and has 2 threaded holes on each end for easier installation.
TDA8950 is available too. Connexelectronic
Old 29th October 2009, 08:18 PM   #508
Rightbrained is offline Rightbrained  United States
I am looking forward to trying out the TDA8950's I ordered and will post my impressions once I have them up and running.
Old 31st October 2009, 03:35 AM   #509
rhing is offline rhing  United States
rhing's Avatar
Hi Cristi,
Do you think this would be suitable for my Virtue Two Class T amplifier?
Here are the amplifier's specifications:
  • Stereo integrated amp based on 1 x Tripath TC2001 controller chip and 2 x Apogee DDX2240 power chips.
  • Max 30v, 90+ wpc @ 4 ohms
  • 22,000 uF power capacitor
  • AuriCap input capacitors
  • Cryo-treated Auric hookup wire
  • Heatpipe thermal management
  • Tellurium copper Propeller Posts
  • Tellurium copper RCA jacks
  • Buffered mono subwoofer pre-out
  • Dimensions of 5"H x 2 3/4"W x 5.5"D
At 30-32V, what would be the power supply's output current? I have Virtue Audio's 130W 30V/4.3A SMPS, but I think it could always use a bit more power to really take this amplifier to another level of performance.
Rich
Old 31st October 2009, 10:17 AM   #510
Banned
i am not familiar with this particular amplifier, but if the power supply requirements are within the smps specs, then is suitable. the output voltage of the smps can be adjusted within +-26 to +-30V limits, and the continuous output current is between 4 to 5A depending on the output voltage, peak current 6 to 7A. the nominal output power of the supply is 250W and the peak power is 400W. when the mains voltage is 110V, the output power will be derated to 200W continuous and 300W peak.
NEW Audio amplifier kits, modules and many others.Hide this!Advertise here!
8 GB150D amplifier modules and 4 GB150S2 power supplies from ska-audio.com Didush Swap Meet 0 1st August 2009 09:06 PM
LM3886 Chip Amplifier Stereo PC Boards, Kits, and Assembled & Tested Modules Jackson Audio Vendor's Bazaar 2 8th April 2007 12:17 AM
Audio amplifier project kits syber Chip Amps 2 6th December 2006 07:42 PM
Copyright ©1999-2017 diyAudio
